Old 6th October 2017, 06:06 PM
Conquistador's Avatar
Thought I'd add just a couple of pics to this thread for reference (and as a reminder to owners to check theirs every now and then!)
Currently '8-less
Previously:
- D3 A8 3.0 CVT
- D3 3.7 V8
Old 25th September 2019, 06:19 PM
Furryhobnob Furryhobnob is offline
Had a rough week with the missus getting admitted nearly a week ago with a burst appendix, and shes had to have further surhery since and we've now missed a family holiday to corfu.
Anyhow went to get in the car this morning to be greeted by a swimming pool in the drivers footwell, didn't have time to investigate as i was on the way to the hospital so used another car.
Just got home so will have to have a look tomorrow, any advise as to which drains to check please
Old 25th September 2019, 08:17 PM
Nognar Nognar is offline
HVAC orange drains by the transmission tunnel
2002 Audi D2 4.2 S8 - Ming Blue Pearl
2002 Audi D2 2.8 A8 QS - Audi Silver
Old 26th September 2019, 09:00 AM
I'd agree with that - take the side trim off to the drivers side transmission tunnel / footwell area and you'll see it there.
Sod's law these things always come along together - hope the missus feels better soon and you manage to re-sort a holiday
Old 26th September 2019, 09:37 AM
I went to check the drain behind the footrest, but its bone dry there, it seems to be dripping from the dash as the bonnet release has water on it, any other ideas?
Old 26th September 2019, 09:39 AM
In that case could either be blocked sunroof drain, blocked scuttle drain or windscreen leak
Old 26th September 2019, 11:35 AM
Mine was the aircon drains!!
ID:	22169   Click image for larger version
ID:	22170   Click image for larger version
Old 26th September 2019, 11:44 AM
Where are these located?
Old 27th September 2019, 07:33 AM
Either side of the tunnel up nearly as high as the top as the footrest but back towards the driver by about 9 inches as per pictures for drivers footwell. The other side is reflected on the other side of the transmission tunnel but same position
Old 27th September 2019, 07:39 AM
Thanks for your help guys, going to stick it in the garage and investigate when i have time, if it is the ones you're talking about, is it a case of just emptying the water in there, or did you use some compressed air or something to try and unblock wherever it is blocking from?
