S8 Ingiter
Hi all. My N/S xenon does not work so I decided to change the bulb - nothing. I managed to put it back together but it was very difficult, the igniter just about turned right into the closed position.
So today I decided to swap over the igniters to eliminate them as the fault. I took the O/S off but I cannot get either of them back on! Is there a knack to putting them back on? I have lined it up, pushed in as far as it goes and it seems flush but it will not turn to lock into place.I have tried to make sure the metal locking spring clip is out of the way. Help! |
OK I sussed the bulbs out but this is the error for the N/S headlamp if anyone can help
Code:
Address 09: Cent. Elect. Labels: 4E0-910-279.lbl Control Module Part Number: 4E0 910 279 S HW: 4E0 907 279 S Component and/or Version: ILM Fahrer H16 0240 Software Coding: 0133121 Work Shop Code: WSC 02313 785 00200 Additional Info: 4E2910113C Wischer WWS D3 H60 0440 8K0910557 REGENLICHTSENSORH04 0003 VCID: 387EA3A74B1C8E84E0-806C Fault Codes have been Erased 1 Fault Found: 00978 - Lamp for Low Beam; Left (M29) 010 - Open or Short to Plus Freeze Frame: Fault Status: 01101010 Fault Priority: 2 Fault Frequency: 1 Reset counter: 193 Mileage: 148690 km Time Indication: 0 Date: 2018.05.28 Time: 14:29:38 Last edited by homer simpson; 28th May 2018 at 05:32 PM. |
So I finally found the culprit - the ballast. Such a pain as two of the bolts are accessible but the third is not so bumper off and lights out. Swapped them over and the n/s worked but o/s didn't. New ballast ordered, should be here in a few days.
2008 (facelift) S8 with B&O, ACC, glass sunroof, reversing camera, front and rear heated seats, ceramic brakes, homelink, electric side and rear blinds, ski load through, heated fan washer jets, remote boot closing, de-flapped manifold, fridge, umbrella holder |
