installed new compressor this morning.Went well , no drama on the installation.
However when i replaced the relay i removed the 40amp fuse for better access ,put the new relay in and forgot to replace the fuse. Put everything back and jumped in the car and started it , no compressor noise , no movement of the suspension , i was heart broken. Until i thought ,did i actually put that fuse back in???????? So carpet back and low and behold no 40 amp fuse in , put the fuse in and replaced carpet and trim. Started the car and bingo , compressor fired up the car raised up without an issue , all 4 corners. I have never seen it move positions so quick , infact i think my compressor has been on the ragged edge since i got the car, and the new compressor is much quieter. Impressed with the replacement compressor ,came with new brass ends for the output connector ,my original was bunged up with either sealant or threadlock , would definitely recommend them , excellent delivery time aswell. Just need to do the adaptation , this were a must ask a question. I have 12.12 vcds and i ran the adaptation but when it gets to 05 to store ,it flashes theres nothing available for section 05. I will try the adaptation again tonight when i get home. PWACKA8
2012 4.2TDI SE EXEC |
