Old 12th June 2015, 01:11 PM
I just had a look online and the difference seems to be whether or not it's left or right (obviously) and whether it also has the reflector and bulb carrier (for rear fog presumably). i.e. RHD or LHD version.
According to Vagpart.com where I looked all D2's are exactly the same, irrespective of year or PF/FL.
I prefer to have 2 rear fogs rather than the standard 1, so bought the missing bulb carrier (from A8parts obviously) for the non-fog side and fitted it myself. Wiring is already there taped up; you just punch out the blanking plastic to use the socket which is already moulded in.
For a reflector I bought some silvered/metallised adhesive tape and fed it into the hole in segments as dismantling the unit didn't look feasible.
Old 12th June 2015, 01:17 PM
Or maybe not.......... The rear fogs are in the cluster in the boot lid.
Old 12th June 2015, 02:17 PM
barzya8 barzya8 is offline
Many thanks Matty & HPsauce,
The one I need is the N/S wing cluster.
I thought both PFL and FL models used the same cluster.
I think the rear bumper is different on the FL model to allow for the chrome strip underneath the light clusters. Unless someone on here knows otherwise.
Thanks,
David
Guildford, Surrey
Bose sound system.
Audi Navigation Plus.
20 inch Final Edition alloys
Old 14th June 2015, 11:50 AM
Yes, it's the bumper that is different, not the lights.
Just happened to be looking at the rear lights on mine and I noticed (never had before) that BOTH the boot lid and corner clusters are marked L or R as appropriate, moulded into the plastic cover.
On the corner cluster it's near the lower front corner.
The part number and Audi logo is also moulded in, pretty much on the corner, so easy to check.
My FL S8 NSR indicator cluster is marked L 4D0 945 095. Offside is R 4D0 945 096.
