Old 11th April 2012, 10:37 AM
SyncroS8 SyncroS8 is offline
Default Options Codes
Ok so who's got the list then
MG
Old 11th April 2012, 10:39 AM
http://igorweb.org/equidec/
Old 11th April 2012, 11:05 AM
I'm going through them on ETOS just for the hell of it!
EOA - no idea
4UF - Driver and front passenger airbags with possibility of deactivating front passenger airbag
6XL - Exterior Mirror, Automatic anti-dazzle, electrically adjustable heated and folding with memory
5SJ - Exterior Mirror Convex
6TS - no idea
1KW - 280mm x 22mm rear disc brakes
J1G - 450A(92AH) Battery (large!)
1ZL - 323mm x 30mm 17" front Brembo Brakes
1AT - ABS with EDL and ESP (had no idea it had this!)
1BD - Sports-type running gear (suspension?)
3FQ - Electric Sunroof, sliding/tilt with Auto preselection
5MW - Dark Myrtle trim inlay for dash, central console and door panels
7X2 - Parking sensors
FOA - no idea
0L2 - Accelerator with electronic module (?)
8GT - 90-150A Alternator
0G7 - Tipronic Auto Gearbox
0YU - Rear axle weight class - weight range 18 (?)
0JK - Front axle weight class - weight range 10 (?)
T7S - 4.2ltr engine (code: AUW, AQH, AKB, AGF, ARU, AVP, AYS, AUW (not sure why AUW is on there twice!)
BEC - no idea
U0L - no idea
X2B - no idea
1N1 - Hydraulic Power Steering
2ZP - Sport Steering Wheel with Airbag for Tiptronic
3HA - Trim general - too much to copy from ETOS!... lots of cloth.
8Q3 - Automatic headlight range control, dynamic (Xenon plus?)
8Z5 - Engine cooling system version 1 (there are options for version 2 and 5... anyone?)
M8G - 8 Cylinder engine, 265KW, AQH, AVP, BCS, AYS
7Q2 - Navigation System
C9T - Alloy wheels, 8Jx18H2 ET48
7K0 - no idea
4X4 - Front and rear side airbags with head airbag
3L4 - Front seat electronically adjustable, driver's side with memory
4KP - Heat-reflective glass (laminated) for door, side and rear windows (Green)
3Y0 - no idea
4K4 - Central Locking with radio remote, interior operation and separate release of luggage compartment
5D1 - Radio Remote Control Central Locking System (433,92MHZ)
1SA - no idea
5Z0 - no idea
Q1D - Sports seat, front and rear
4GP - Windscreen glass (laminated) with tinted zone and view window for chassis number
Anyone any idea of the ones which have 'no idea' next to them?
MG
Old 11th April 2012, 11:10 AM
Thanks IT,
Putting the last few in...
I get the following:
EOA - No special edition ( )
6TS = Right exterior mirror: aspherical, large viewing field
F0A = No special purpose vehicle, standard equipment
BEC - still no idea!
U0L = Instrument insert with tachometer clock and mph speedometer
X2B = National sales program Great Britain
7K0 = Without tire pressure warning light
1SA = Without additional front underbody guard
5Z0 = Without separate power seats rear
Not bad.
MG
Old 11th April 2012, 11:23 AM
The 'O's and Zeros are incredibly hard to tell apart - Where you have no output, try switching them, it usually gets results....
Usually 8's and B's have the same trouble, but your sticker looks unusually clear
Old 11th April 2012, 12:05 PM
Ahah... ok so I'll try the BEC as 8EC
8EC = Bi-functional headlight with gas discharge lamp, for driving on the left
Makes more sense
MG
