water noise from dash
recently im getting a gurgling or sloshing water noise from behind the dash, it seems to only be there when the climate is on and onlys lasts a little while before dissapearing
anyone got any ideas
______________________________________________ A8 4.2TDI - Ice Silver, Comfort heated/cooled/massage Seats, Alcantara, Extended Leather pack, Ambient light pack, Solar roof, Night Vision, Lane change assist, Audi presense, Audi BrakeGuard, ACC Cruise, Blinds, Quad Air, AMI, Online services, Parking with rear Camera, Aluminium brushed inlays, Adaptive Zenons, High beam assist, Bose Sound, and more Gone but not forgotten: A8 D3 2005- AMI HDD, Audible Parking, TV, NAV, Bluetooth, Hybrid TV, Aftermarket headrest monitors, Rosstech VCDS / Vagcom |
I would have a check of your air con and plenum drains as soon as, you don't want wet carpets and electronics
Del |
Yep, sounds like that if it's coming from the centre vents ^ ^ ^ ^
why does it only last a short time then? does it evaporate once working
anyone any idea on how to check the plenum drains, i dont have elsa loaded at the moment
There is a rubber elbow each side of the trans tunnel where the Center console and dash meet, it's hidden under the carpet.
the drains will presumably still be blocked though
Mine are due a de-clogging too - same symptoms - just started sloshing a few days ago. I would leave your air-con off (eco) until you've had chance to clear them to prevent further water build-up.
Or push something up the hoses that go up to the catch tray in the dash, a thin flexible cable of some sort.
http://www.audipages.com/Tech_Articl...rdrainsD3.html
These are the ones I think you should check first
Del |
