Old 24th March 2021, 08:27 PM
On to the driver's side head. Some impressive tramlines in this tensioner!
This head has been apart before and whoever did the work didn't re-seal the end cap, hence the oil leak at this end. You can see the original sealant is dark and contaminated with oil
The end of the head is too clean! No trace of sealant here.
It has been apart to replace the tensioner, and one of the dowel sleeves got lost in the process. There should be two here. Unfortunately, these are not available as a spare part.
The sleeve isn't stuck in the tensioner either. The gauze has disintegrated on this side and gone through the tensioner, as usual. Luckily the start pin still locks up, but the non-return valve isn't functioning any more so oil can leak back out of the tensioner. This will rattle a little bit on start up but not destructively so.
Luckily I am a high-functioning hoarder so I have a dead cylinder head in a box which can donate a dowel sleeve
and here it is
The non-return valve, not valving and dribbling slightly
Both dowel sleeves holding the new gasket in place
Assembly lube on the cam
The merest whiff of sealant on the end cap. Less is more here - too much and it will block the oil drains
A tiny but even bead squishes out when the cap is bolted down. No more leak here.
New knock sensors
One of the water pipes back in place
The water temperature sensor is rusted in place so I will remove this and replace it while the engine is out. If this were to fail with the engine in place it would not be a pleasant job to replace it with it being so crusty, and a Febi replacement is £6
ID:	25928   Click image for larger version
ID:	25929   Click image for larger version
ID:	25930   Click image for larger version
ID:	25931   Click image for larger version
ID:	25932   Click image for larger version
ID:	25933   Click image for larger version
ID:	25934   Click image for larger version
ID:	25935   Click image for larger version
ID:	25936   Click image for larger version
ID:	25938   Click image for larger version
ID:	25939   Click image for larger version
ID:	25940   Click image for larger version
ID:	25941   Click image for larger version
ID:	25942   Click image for larger version
Old 25th March 2021, 08:42 PM
The temperature sensor actually came out in one piece after soaking overnight in WD40, but it is so corroded I will replace it anyway.
A bit crusty in there! It cleaned up find with scotchbrite though
Inlet manifold back on
On to the front crank seal which was weeping a bit. I had to use a bearing puller to get the sprocket off which is highly unusual. It turns out there was some corrosion in there which I've not seen before
Rust spot on the crank - this cleaned up nicely with scotchbrite too
The crank pulley is a mess. Ricky mentioned this fell off a few years ago, and it is very bruised from where it was rattling around before it let go. I will replace this with a good used one as its not really salvageable without a lot of work, and the bolts don't torque up properly with it in this state. They sort of squish in to place rather than seating nicely which doesn't bode well for it staying place in the future.
The new seal was fitted with the special tool I made for the last engine
New bolt torqued to 200Nm + 180°
ID:	25944   Click image for larger version
ID:	25945   Click image for larger version
ID:	25946   Click image for larger version
ID:	25947   Click image for larger version
ID:	25948   Click image for larger version
ID:	25949   Click image for larger version
ID:	25950   Click image for larger version
ID:	25951   Click image for larger version
Old 25th March 2021, 09:00 PM
Hi MJ, are you tourqueing against the crank locking pin only?
Paul
Gosport UK
________________________
Audi S8 2002 FE Avus Silver / Extended Red Leather.
Daily Driver: BMW 3 series GT - Just more practical for my camping trips!
Old 25th March 2021, 09:20 PM
Yes, just the locking pin - thats what the spec says. I have to stand on one leg of the engine stand while applying force to the 1m long breaker bar to get the 180° so that the whole lot doesn't just flip over!
Old 26th March 2021, 08:39 AM
I have always had a concern that the high torque requirement for the crank bolt might sheer off the end of the locking pin.I tend to try and lock the crank using the old timing belt. That said, I've not done the front oil seal on an a8 yet but have done it twice on a v6 A4 (B6). Timing gear setup is different but crank pulley is the same and torque requirements the same.
Audi S8 D2 2002 88k mls
Old 26th March 2021, 08:58 AM
89forever's Avatar
89forever 89forever is offline
you MUST not torque up using the belt method, you are putting the full force of the torque against the woodruff key on the pulley which is only a cast piece, you will sheer this and destroy your engine.... the workshop manual and how MJ does it is correct.
The factory way of holding the crank whether V8, V6 or inline 5 are the only way to do the belts...
89forever
Current stable.....
‘07 A8 D3 4.2tdi
‘08 S5
‘09 A4 Avant 2.0tdi
‘04 TT 225
Old 26th March 2021, 09:04 AM
89forever's Avatar
you must always inspect this area and change the pulley as a matter of course if in doubt... the pulley is cheaper than a wrecked engine...
i speak from years of inline 5 experience and too many destroyed engines sadly.... i learned the hard way... the toothed belt version of the V8 shares a similar pulley arrangement.
89forever
Current stable.....
‘07 A8 D3 4.2tdi
‘08 S5
‘09 A4 Avant 2.0tdi
‘04 TT 225
Old 26th March 2021, 09:30 AM
I wonder if we will ever see a WITW where MJ strips it down to find everything has been done properly before it arrived in her workshop?
I’ve said before that I’ve twice been charged by different ‘Audi Independents’ for Audi parts for a car belt change, to discover at the next change that non-Audi parts had been used.
And I once paid for an indy to my tracking yo find that when I picked the car up that the steering wheel was heck of an angle - they’d taken it around the corner to Kwik Fit as their machine was broken!
Goodness knows what else that I don’t know about. Thank goodness my car’s had a visit to The Doctor.
Old 26th March 2021, 10:50 AM
"The new seal was fitted with the special tool I made for the last engine"
How many "special tools" do you have?
Old 26th March 2021, 11:01 AM
There's a drawer in the toolbox just for special tools Mostly home made replicas of the factory items, although I do have a few manufactured ones too, mostly for engine timing.
