Old 31st October 2015, 02:21 PM
Default Free - old laptop with VAGCOM/VCDS-Lite
So, only of use for D2's really, but it's about the same vintage as it was built in December 1998 by IBM in Greenock!
I used it for many years to run VAG-COM so it's complete with serial OBD-II lead, bag, mouse and various accessories. Free to a good home if collected!
It's battery is pretty poor (max 30 minutes) so you really have to run a long mains lead out to the car, but apart from that it works fine.
It's an IBM ThinkPad 380Z, built like the proverbial brick privy so almost indestructible, running Windows ME. Made in Scotland from Girders!
Pentium-II processor, a mighty 96MB ram and 7GB hard disk. CD and floppy drives and a solitary USB port too!
It even has a Belkin PCMCIA wireless adapter with it but although it's 802.11g it often won't connect to most modern wireless routers.
There are various versions of VAG-COM on the disk. One of these was properly registered and most definitely worked, but I deactivated it to upgrade to VCDS-Lite on a newer laptop. (And even that has now been superseded)
Also has VCDS-Lite installed and tested with the enclosed lead.
As you presumably know the unregistered version of VCDS-Lite is still pretty useful.
If you can't be bothered with a mains lead you can probably buy a power adapter that will generate the 16V DC it uses and plug into your car 12v power outlet. (I have a 19.5v one for my Dell VCDS laptop)
PS. It also has a full legal copy of Office 2000 installed!
Old 1st November 2015, 03:37 PM
oldnick oldnick is offline
yes please ...as answered in the sensors thread !
Old 1st November 2015, 08:57 PM
OK, PM me about arranging to pick it up.
Old 8th November 2015, 09:03 AM
Collected this morning. Good to see a computer as old as some of our cars still working productively.
