Old 16th March 2010, 10:40 PM
Hi Oli, I've actually lost the TV function but seeing as analogue TV is going to be cut of soon I didn't mind. To have a digital TV tuner working with the RNS E is 3/400 I understand. I can't justify that as I could just use the TV catchup app on the I Phone.
I need to buy a AV connector to plug into the back of the RNS E.. This will then let me watch I Phone videos, TV Catchup and play music from it for £80. However to get full control of the I Pod from the headunit is £200 so I'm in no hurry to do that, yet. The Rearview cam will also have to connect in the same way or through the Tuner IIRC but not doing that just yet either.
Next RNS E upgrade will be the bluetooth module.
Even though I've lost a few things, I didn't use them much anyway. The E is soo much better then the D. The whole interface and navigation, tmc is very modern. The SD cards are also particularly useful, just plug it into your computer and drag and drop music files, you can also arrange it into Artist > Album> etc... so its all neat. I really recommend it.
Old 17th March 2010, 07:21 AM
Dam you.... you beat me....
Looks good.... I'm very close to sorting mine out, eta for the whole car is less than a week hopefully....
Old 17th March 2010, 12:27 PM
Ian, there is no way I would have been able to finish this without your excellent write up, it made the process very simple. Can't thank you enough.
Old 18th March 2010, 05:56 PM
So now I have my tail lamps in and no bulb warning light, you can see the DIS clearly showing the MP3 info. Cool
Old 18th March 2010, 06:24 PM
Looking good mate... All you need now is some decent music to go with it
Old 18th March 2010, 06:49 PM
Thanks, but you guys gotta remember I was born in 1990 so my idea of good of music will be a lot diffrent to yours, although a lot of it is 80s
Old 19th March 2010, 12:29 PM
A8 Doc A8 Doc is offline
Young git lol.
A note that the standalone GPS antennas will work through the dashboard. Just get it as high up as you can
I use one that a retrofitted my COMAND NTG2.5 into my Eclass and it's better than standard one.
Old 20th March 2010, 01:16 AM
I have mine on top of the steering column right now as its only a temporary measure until a fully working adaptor arrives. Picks up 7/8 satellites so I'm happy with that.
Anyway... I have just done 8 hours driving in the S8 with the RNS E and I really don't like the navigation aspect of the RNS E. On the D the instructions come up the DIS. I loved this feature so much but was willing to sacrifice it, however on the RNS E you have to keep looking down. The 335 with I drive I had didn't have instructions between the speedo but the sat nav was much higher up (at eye level) above the vents which made it easy to glance at, I nearly ran a red light today in the S8 because of the positioning of the E. Maybe I will get used to it, I still wouldn't go back to the D.
Old 20th March 2010, 07:20 AM
You need to delete TV from your signiture....
Old 20th March 2010, 09:13 AM
Done
