Old 21st July 2015, 09:18 PM
Some pics for your amusement...... (someone needs to get a laugh out of all this!)
Still got one to go
Nick
Old 21st July 2015, 09:29 PM
It's verging on criminal to over tighten them to that degree! That's proper rattle gun job done on max torque....
Always comforts me when a tyre fitter/mechanic appears to know what a torque wrench is intended for
Old 21st July 2015, 09:30 PM
That looks like a Ford locking wheel bolt & nut.
Old 22nd July 2015, 10:05 AM
Had a close one on my D3 with the same daft locking nut, thankfully it wasn't too chewed and my local place managed to straighten it enough to get it to engage.
Old 22nd July 2015, 10:15 AM
One very good reason I stick with my mobile tyre man, he always uses a torque wrench to set them properly.
And to be fair my local independent garage are the same, they even detail the wheel refitting and torque settings on the signoff sheet they give you.
Old 22nd July 2015, 08:35 PM
Well done for sorting it. What a saga!
I fear all tyre fitters now
Old 22nd July 2015, 09:49 PM
Still got one left to get out.......
..... but I scored another key today at a scrapyard close to work. When I enquired I was led to a corner of their workshop where there is a plastic crate about 2 feet in all directions full of various wheel nut keys!
He found me a chair and another crate to sort them into. Took about 15 minutes and 1/3 of the crate to find the right one. It's in good shape. Hope it's feeling strong! If it works it was £ 5 well spent!
Question is, do I try myself or go to a tyre fitter with a big rattler gun
Nick
Old 23rd July 2015, 07:34 AM
andycaca andycaca is offline
i would be tempted to use an impact gun. then you can lean into the socket and ensure it doesnt rise and slip off
good luck with the final one
2001 S8 D2
Old 23rd July 2015, 10:08 AM
It's off! Big breaker bar did the job.
That's a relief!
Now I can investigate why this wheel (Right rear) has 4.5mm toe in and 2º negative camber....
Nick
Old 23rd July 2015, 11:14 AM
That's a relief!
Nick
probably caused by the torque from when they put the wheel nuts on!!
