Old 26th July 2019, 06:02 PM
Nognar Nognar is offline
Default Time for a new Alternator (Update: New Battery)
Well it seems to be the warm weather has upset the S8 a little.
Went to drive it today and it had a little trouble! Jumped it OK (Anker Jump Pack highly recommended as it starts a 4.2!) and drove from that point fine over a 20 mile test route.
Started OK after that and seemed to be back to normal. Looking at VAGCOM I am only getting 12.5v when running on the measuring blocks (The 2.8 A8 gets 13.7v as a comparison), confirmed this also with the good old multimeter.
It seems the S8 has lost a couple of vital volts when running.
Battery is good (tested) and is in fact a reasonably new Yuasa Silver, so do not expect that to be the cause. Therefore it looks like a new alternator is needed to me. Now the old one has done nearly 199,000 miles so its best years are behind it and provided good service.
What's the Alternator of choice?
Euro Car Parts have a Lucas (150A Model - 401441231) one for £335 using there daily magic codes or CarParts4Less for £287.
Though Gloucester does have a specialist that reconditions starters and alternators so may try that instead.
2002 Audi D2 4.2 S8 - Ming Blue Pearl
2002 Audi D2 2.8 A8 QS - Audi Silver
Old 26th July 2019, 07:22 PM
Make sure you get a V8 one. Many parts outlets sell the V6 one claiming it's the same as the V8. It'll bolt up, but the cooling air inlet is in a different place.
Old 26th July 2019, 11:04 PM
Thank you and good to know.
Last time I did an alternator was on a C4 2.8 Quattro
Old 27th July 2019, 10:37 AM
johnny_quattro's Avatar
Yuasa Silver battery? Don't commit to an alternator at this stage as I've had loads of issues recently. Let me dig out the thread and I'll report back...
(Too long, didn't read) summary - it was the battery, local auto electricians tested it and it was useless, 8.5V under 300 amp load.
Last edited by johnny_quattro; 27th July 2019 at 10:38 AM. Reason: too long didn't read became emoticon due to semi-colon
Old 27th July 2019, 10:40 AM
Here's my thread detailing the problems I've had recently with alternator/battery/electrical distribution connector block on front chassis rail...
http://forum.a8parts.co.uk/showthread.php?t=15074
Hope this helps in some fashion.
Old 27th July 2019, 01:05 PM
Interesting read and thank you.
Seems the battery may not be as good as I thought.
I will swap it round with the one in the A8 and do some further testing.
Old 27th July 2019, 04:54 PM
My car now starts like an excited puppy, barely a revolution of the starter motor and off she goes, desperate to go somewhere. Before the battery was replaced and after all the 'testing', it was sluggish and took around 8-10 revs of the starter motor. The worst attempt took around 6 seconds, and no wonder really with the Yuasa showing just 8.5V under load when tested.
After the auto electricians recommended a new battery, I took the option of swapping my Yuasa Silver for a spare battery out of a Ford Focus C-Max (no-name brand job). Took a bit of jiggery-pokery as the battery is about half the size and I had to raise it slightly and support it to get the battery terminals clamped. This battery had been sat for 5 months and it fired up the Audi in an instant. I was then able to transport myself and the car in order to get the new Bosch battery fitted.
Cheers.
Last edited by johnny_quattro; 27th July 2019 at 04:55 PM. Reason: Hideous use of a comma instead of a full stop.
Old 17th August 2019, 12:26 PM
Spent some time with the car today and can confirm the root cause of the problem is the battery.
Therefore I cannot personally recommend to anyone a Yuasa Silver battery.
More interestingly I tested it again this time with an Autel Battery tester (AL539B and recommended as I bought it specially for this as the cheap battery tester thought my battery was good) and it confirmed on the CCA test it needed to be replaced. It also confirmed that charging from the Alternator was all OK from the car. The readings I had originally on VAGCOM were down to the battery not the condition of the alternator, hence it was not taking a full charge.
Went to take it back to Halfords and to rub salt into the wound they refused to replace the battery as it tested fine on their machine. Battery had a 5 year warranty, was well within that and I had the receipt.
But hey there you go a lesson learnt.
I will write to Yuasa to see if there is any interest from them as its all in a little disappointing.
Old 18th August 2019, 08:06 AM
Strong, very strong, letter to Halfrauds required.
Old 10th October 2019, 07:48 PM
Just wanted to provide an update on this one. Since replacing the Yuasa Silver battery with just a basic one the car has been perfect.
All the problems of a flat battery after a few days, not charging and just being a headache have disappeared.
Car has started quickly and perfectly when required, it’s been been left for a week or two without a problem and has done many cold cranks without fault.
