What size is this tubing
Hi
Have a split in this tube that attached to the bellows on my D2 S8 I've already replaced the braided hoses that are 5/32" - but any idea what size this tube is?? Thanks |
I didn't want to remove the pipe in case I bugger it up and haven't got a replacement sorted |
Not 100% sure but I think it is 3.2mm ID diameter vacuum hose. I will be fairly thick walled 7-8mm outer diameter.
Thank you
