D2 - Wheels and Tyres Refurbing, center caps, tyre brands, tyrefitters - discuss it here |
I do recall reading somewhere a post (maybe not here) about how critical tyre brand/shape was at that particular size limit. Some are OK, some not.
2003 D2 FL S8. Irish Green Pearl/Beige. Solar sunroof, auto-dim mirrors, electric rear seat functions, ski hatch retrofit; extended leather. Aftermarket DVB-T, reversing camera and full XCarlink (Bluetooth etc.). 2016 Volvo V40 T5 Cross Country (4WD) with ALL the toys including adaptive cruise etc. etc. Osmium Grey with Blonde/Charcoal leather interior. Polestar performance "optimisation". (A much rarer model than a D2 S8 by the way!) Oh, and a brand new engine at just under 30,000 miles on the factory one! Finally: gone, but not forgotten..... 1998 D2 PF S8. AgateGrey/Platinum. Every option (I think) except electric rear seats, tiptronic steering wheel, ski hatch, towbar & dimming door mirrors. e.g. Cruise control, NavPlus/TV, Bose, GSM, Xenons, Solar roof, Parking sensors, Alcantara/leather everywhere of course. (internal dimming mirror added later) 1998 (very early) Ford Focus 1.8 Zetec; ABS/TCS, Heated screen/mirrors, Aircon, Auto-dim mirror, Leather, Trip computer, Cruise control, OEM Ford SatNav with CD changer. And before that a lot of Rover 800s, a few oddities, a lovely Triumph Dolomite 1850HL with Overdrive and way back in my schooldays an Austin Seven aka Mini 850! |
consider Delta Mics or FK auto. Both are CE approved just like the more expensive, for instance FORGE where you pay more for the name.
So basically from advice given here I have two choices.
Run my 275x35x20 tyres with spacers or sell them and buy 255x35x20 tyres. Can I ask how the speedo reading is affected by both ? Basically which one reads more accurately !!!! |
First you need to remember that speedo most likely over-reads with stock tyres, in my expierence when speedo says 80 actual speed is 72-75. So compare speed that speedo shows you to the GPS speed to determine how big the difference is, then you can see use this site to see how much will the reading change and also see how the clearances change. http://www.willtheyfit.com/
Very useful website ainarssems !!!!
Thank you !!! Looks like the 255's are closer to the right speedo readings than the 275's !!! Last edited by Ricky22buk; 28th March 2015 at 06:43 PM. |
I'm amazed Noone has commented on offset or got proper specs on the wheels the OP is running or even clarification of what is rubbing what (tyres or wheels?)!
Yet let's put 5mm spacers on to fix it!! fix what? Is the tyre hitting the upright, or is the wheel fouling the control arms? The way the lower control arms mount to the hub, the only thing that can foul is the wheel itself, the tyres can't physically hit them, unless it's right out on the rear mount (Even then I doubt it). If the wheel itself is fouling, the only solution is spacing it out, that's why the offset is important. A 9" rim should fit fine with a 35 offset. 275's should also fit fine with a 35 offset.
Cheers Marty ____________________ Current: 2001 Audi S8 - Brilliant Black with Black interior, C5 RS6 rims (whenever I actually put them on...), Solar Sunroof, Tinted side and rear glass, RNS-D, Grom, Bose, clunky old phone in arm rest! 2002 Audi S8 - Project Replacement head coming arrived thanks to MJ Silver with Black interior. All features as the '01, with the 'S' mode auto shifter. Dodgey rear tint (need to find a way to get rid of that). Family: 2009 Volvo XC90 V8 R Design - has a louder more obnoxious exhaust than the S8, sounds great! Love this thing - Q7 was double the price, and certainly not double the car! Sold: 1997 Audi A4 - Hamilton's Club Sport, Achat Grey (will miss the old girl) |
Sorry buddy !!!! I probably didn't give enough info !!!!! Running D3, 9 inch wide 20" wheels which I believe are 46mm offset. The wheels themselves aren't fouling, but the tyres do foul against the uprights. I let the car roll forward and the silver of the upright has rubbed on to what I would basically call the corner of the tyre. If you follow the thread across its face and just where you start to fall down the tyres sidewall is where its rubbing. |
To be fair, to regulars here that was pretty obvious from what he said in the first post and everyone correctly assumed what he has now clarified.
Having reread the first post I can now see that he was referring to the inside tyre rubbing on the upright. I wanted to know the wheel offset as I've been reading about another D2 with D3 19" rims running 275's with a higher than spec profile (275/40x19) with no clearance issues. His wheels are D3 turbines which have a ET45 offset. He talks about his tyres missing the upright by a "hairs width" (but a miss is a miss when the distance is fixed). His car also has S8 suspension. Now 1mm difference in offset is bugger all, but might be just enough, or it could be that the tyres on the 19's that this bloke chose have a slightly more rounded shoulder to give the needed clearance. Although the 20's are a 9" wide wheel vs the 19" turbines being 8.5" wide, when talking the same width tyre, the offsets (from centre) should equal out. So in the end, spacing will probably be the easiest option. You can buy 3mm spacers, which may give enough clearance over going to 5mm. May save the purchase of new wheel bolts... ...I'm curious about all this as I'm in the process of buying some 19x9 ET35 wheels and I'm thinking 245's might look too narrow and I was looking to 275's myself. At 30mm, we're taking 15mm either side of centre and in my case I've been wondering about guard clearance. I'm also looking at larger profiles to fill the guards a bit better without altering the suspension. A side benefit of this of course would be a smoother ride... I'll be sure to post to any ones curiosity once I sort out what I'll do!
