#91
Remember how the Murple's mangled gearbox was missing its sump magnets?
I found one of them stuck to the torsen diff I've dismantled the tail section of the dead gearbox to fit the casing to the PF's gearbox in order to solve the broken brackets, so this bit will get cleaned up and swapped over. |
#92
I don't claim to know anything about the inside of the gearbox , question is how do you think in made its way in there ,then final question is was there normally 2 sump magnets and if so were do you think the second ones gone
Audi S8 D3 07MY 5.2 V10 Daytona Grey With Bang & Olufsen Advanced Sound System, Advanced Parking System, TV Analog/ Digital, Rear/Back Window blinds, Front and rear heated seats, Alcantara Roof, Extended leather Pack 2, Extended Aluminium pack, Carbon and Aluminium trim packs, RSE, PS2. Daily driver Audi A8 d4 2014 phantom black 3.0 tdi Previously owned Audi 80 1986 1.8 white Audi 80 1990 2.0 red Audi A4 1996 1.9 tdi green Audi A6 1.9 tdi 2000 blue Audi tt 225 2000 silver Audi s8 d2 2002 fe grey Audi a8 4.0 tdi d3 2006 black Audi a8 3.0 tdi d3 2010 black Last edited by S81; 10th September 2021 at 08:53 PM. |
#93
Further investigation has revealed that there is a slot in the casing for a magnet in the rear diff housing so I suspect that the magnet fell out of the slot while I've been moving around the dismantled bits of the gearbox, and it stuck to the nearest steel thing which was the torsen diff. The three from the ATF sump are still missing.
Certainly whoever 'rebuilt' the murple gearbox never bothered opening the rear casing or replacing the bearings as they are very loose. The torsen housing coming off the PF box: Nice clean torsen. You can see the slot for the magnet directly at the bottom of the casing. The magnet is still in place in this one. PF end housing on the left, murple housing on the right. You can see the two bosses on the right hand one which have been broken off the left hand one. 320k mile never-opened casing with bearings and spur gears removed. 100k mile probably-opened casing with the bearings still in place. These will all be swapped in to the murple's casing and reassembled. |
#94
What's the hall effect sensor and sensor ring on the Torsen diff for? Not Speedo is it?
Cheers Marty ____________________ Current: 2001 Audi S8 - Brilliant Black with Black interior, C5 RS6 rims (whenever I actually put them on...), Solar Sunroof, Tinted side and rear glass, RNS-D, Grom, Bose, clunky old phone in arm rest! 2002 Audi S8 - Project Replacement head coming arrived thanks to MJ Silver with Black interior. All features as the '01, with the 'S' mode auto shifter. Dodgey rear tint (need to find a way to get rid of that). Family: 2009 Volvo XC90 V8 R Design - has a louder more obnoxious exhaust than the S8, sounds great! Love this thing - Q7 was double the price, and certainly not double the car! Sold: 1997 Audi A4 - Hamilton's Club Sport, Achat Grey (will miss the old girl) |
#95
Output speed measurement by the TCU, to make sure that input rpm and gear selection are giving the expected result.
When the gearbox fails and throws a 'gear ratio incorrect' code, its the reading from this sensor that allows the TCU to determine that something is wrong in the clutch packs. |
#96
Found the file but I guess there is no much need now that you have manual ECU.
Not sure why it says 380HP when stock is 340, maybe it's a tuned file also it does seem a too big of an increase or maybe just a typing mistake. It's been a very long time so do not remember details.
#97
Thank you
#98
Cleaned up the torsen housing
Swapped the bearings and spur gears over New gasket - amazingly, this was in stock at Milton Keynes so came overnight The output flange should have a rubber gasket. Bizarrely, whoever put this gearbox back in used silicone sealant instead Thats better Torsen housing back together Flipped it over and primed the oil pump with new Mannol AG52 oil. I did the filter as well but forgot to get a pic. Nearly-new sump Where the magnets should be Sump back on and oily bits finished Engine and gearbox reattached at last. I don't have engine mounting brackets for the 32V so the engine is sitting on carefully calibrated lumps of carbon-foam composite |
#99
Good job you explained that as to the untrained eye it just looks bits of pallets
Audi S8 D3 07MY 5.2 V10 Daytona Grey With Bang & Olufsen Advanced Sound System, Advanced Parking System, TV Analog/ Digital, Rear/Back Window blinds, Front and rear heated seats, Alcantara Roof, Extended leather Pack 2, Extended Aluminium pack, Carbon and Aluminium trim packs, RSE, PS2. Daily driver Audi A8 d4 2014 phantom black 3.0 tdi Previously owned Audi 80 1986 1.8 white Audi 80 1990 2.0 red Audi A4 1996 1.9 tdi green Audi A6 1.9 tdi 2000 blue Audi tt 225 2000 silver Audi s8 d2 2002 fe grey Audi a8 4.0 tdi d3 2006 black Audi a8 3.0 tdi d3 2010 black |
#100
Replacement starter cable compared to the original
Once the starter was back on I filled the engine with oil and spun it over with the magic box until it got oil pressure One of these is not like the others The short coil is the right part number but from a different batch to the others so it has been replaced at some point, but had the wrong spark plug connector attached to it. Surprisingly the engine seemed to run fine, even though this coil wasn't touching the plug Luckily I have a box of spare coil packs so replaced the short one with the correct part Spark plugs and coil packs back in. |
