Old 14th May 2009, 02:41 PM
Zip's Avatar
Zip Zip is offline
Question Adjusting Bi-xenons for European driving...?
Can anyone tell me what's required to change the beam pattern on a 2002 S8 for driving on the right? Is it a dealer-only adjustment?
Ta in advance,
Zip
Old 14th May 2009, 04:47 PM
gninnam gninnam is offline
Believe it is stealer only - had a look myself last year - ended up not bothering and drove around France for 3 weeks - 95% daytime driving
Old 15th May 2009, 07:55 AM
I've looked into this breifly in the past.
The Standard facelift xenons (which you're unlikely to have on a 2002) should have a switch in them which allows you to move the beam pattern dead central, which is acceptable for european driving...
The Xenon plus which you will most likely have I seem to recall are unadjustable and dont need a adjusting for use on the continent. Now, I dont really understand how that can be, so I'm just blindly passing on something I read somewhere (!)
Might be worth a call to the stealer to confirm, but I confess after years of worrying about it, sticking crap to my headlights and farting around, I now work on the basis that in summer months 90%+ of the time is spent during daylight hours, dusk you can run on sidelights and for the few moments you need to use your headlights, they'll get over it
(Probably should insert some dislaimer here about how its not a good idea, I dont condone it, etc etc, you get the gist, you're on your own...!)
Old 15th May 2009, 08:01 AM
Wow... Looks like i was right... Its been a tough day, best sit down for a bit
Servicing headlights
Converting headlights for LH or RH traffic
When driving in countries where traffic drives on the side opposite that of the homeland of the vehicle, both headlights must be adjusted so that the asymmetrical dipped beam does not impair other motorists' vision.
Note:
Bi-xenon headlights do not need to be converted.
  • Remove large housing cover from headlight housing.
  • → Check the switchover lever position -1- for both headlights.
Left headlight:
    • Lever down = right-hand traffic
    • Lever up = left-hand traffic
Right headlight:
    • Lever down = Left-hand traffic
    • Lever up = Right-hand traffic
  • Move the lever into the desired position as necessary -arrows- until it engages -arrows-.
  • Reinstall the housing cover.
Old 15th May 2009, 03:07 PM
Zip's Avatar
Zip Zip is offline
Question How bizarre...
...I really don't understand how the Xenon pluses can not need adjusting. I'm sure the beam pattern on dipped points to the nearside of the road...will have to check later.
Thanks for the research...when the gendarme pull me, I'll just say "Ian told me I didn't need to do anything".
In my best French, of course...
Zip
Old 15th May 2009, 03:23 PM
nope, makes no sense to me either....
Beam patterns should favour the pavement, and when driving on the wrong side, you should thus be blinding other drivers...
oh well
cest la vie..
