Old 9th October 2013, 06:38 PM
Default Fault codes from our A6
I checked for stored faults and cleared them a couple of weeks ago - my wife reported that the airbag warning light came on again today so I've rescanned and got the following:
VCDS Version: Release 908.0
Data version: 20090911
Wednesday,09,October,2013,18:00:54:13314
Chassis Type: 4B - Audi A6 C5
Scan: 01 02 03 06 08 15 16 17 18 34 35 36 37 45 55 56 57 65 67 75
76 77
VIN: WAUZZZ4B
Address 01: Engine Labels: 06C-909-559-ASN.lbl
Part No SW: 8E0 909 559 M HW: 8E0 909 059
Component: 3.0L V6/5V G 0010
Coding: 0011752
Shop #: WSC 02334 785 00200
No fault code found.
Readiness: 0000 0000
Address 02: Auto Trans Labels: 01V-927-156.lbl
Part No: 4B0 927 156 EN
Component: AG5 01V 3.0l5V RdW 0811
Coding: 0000001
Shop #: WSC 00000 000 00000
Address 03: ABS Brakes Labels: 4B0-614-517.lbl
Part No: 4B0 614 517 H
Component: ABS/ESP allrad 3428
Coding: 06397
Shop #: WSC 02334
Address 08: Auto HVAC Labels: Redir Fail!
Part No: 4B0 820 043 AQ
Component: A6-Klimavollautomat 0208
Coding: 00101
Shop #: WSC 00000
Address 15: Airbags Labels: 4B0-959-655-AI84.lbl
Part No: 4B0 959 655 AA
Component: Airbag 8.4EP 1002
Coding: 0001106
1 Fault Found:
01212 - Belt Tensioner Igniter; Rear Passenger Side (N197)
001 - Upper Limit Exceeded - Intermittent
Address 17: Instruments Labels: 4B0-920-xxx-17.lbl
Part No: 4B0 920 981 K
Component: KOMBI+WEGFAHRS. VDO D14
Coding: 00462
Shop #: WSC 00046
WAUZZZ4B44N065033 AUZ7Z0C2476731
Address 35: Centr. Locks Labels: 4B0-962-258.lbl
Part No: 4B0 962 258 N
Component: Zentralverrieg.,DWA D38
Coding: 06891
Shop #: WSC 02334
1 Fault Found:
01134 - Alarm Horn (H12)
76-10 - Terminal 30 missing - Intermittent
Address 45: Inter. Monitor Labels: None
Part No: 4B0 951 178 A
Component: Innenraumueberw. D04
Coding: 00102
Shop #: WSC 02334
Address 56: Radio Labels: 8E0-035-1xx-56.lbl
Part No: 4B0 035 195 Q
Component: symphony II NP2 0470
Coding: 00201
Shop #: WSC 00000
Address 76: Park Assist Labels: 8E0-919-283-8E2.lbl
Part No: 8E0 919 283
Component: Parkingsyst. A6 RDW D09
Coding: 01116
Shop #: WSC 02334
End ---------------------------------------------------------------------
The airbag fault worries me as it appears to be the nearside rear seatbelt pretensioner, which is where my son sits in his car seat. I've tried to find info on this online and it suggests long term baby seat use can cause this fault, but not been able to find any info on the actual cause or how to rectify it. Am I looking at a complete seatbelt assembly to sort it properly or is it simply down to the seatbelt not being reeled back in regularly?
The alarm fault I don't know what to look for - no idea what terminal 30 does, or where it is! Not sure how it can be intermittantly 'missing' unless it's just a bad connection?
Apologies this is A6 related but hoping someone here will know!
Adrian
Old 9th October 2013, 06:45 PM
The alarm fault could be that the battery inside it has leaked and damaged the electronics.
Is it easier to get at on an A6?
