Old 27th October 2011, 05:05 PM
lol thats amazing detail Ian - I wonder how much the heated steering wheel actually was as an add on option
Old 28th October 2011, 02:07 PM
The heated steering wheel is controlled directly by the 6 position drivers heated seat switch.
The mini circuit board on the steering wheel takes the data from the bus, uses the +12 supply through the bushes to heat the wheel to the desired level.
Amm... It works a little bit different.
Driver's heater switch works as steering wheel on/off switch, but we cannot manually control temperature with this switch. When switch is in non-zero position the heater circuit inside the steering wheel engages, and that circuit uses temperature sensor located inside the steering wheel itself to prevent it from overheating.
And yes, external temp sensor doesn't affect it.
Old 28th October 2011, 02:46 PM
Dam it. I think hes probably right. I'll get my coat....
Old 28th October 2011, 03:10 PM
Don't get your coat Ian.
Old 1st November 2011, 08:49 AM
well all i can say is that when i used to put my heated seat on full my steering wheel used to heat up as well that was regardless of the outside temp ? now they are both intermittant they will not come on when i set it to 6 all other seats work fine, and the steering wheel and heated seat will come one if left on 6 randomly every now and again but not on demand when i ask it to ?
Old 2nd November 2011, 03:38 PM
Guy, sounds like switch to me.
Buy switch (maybe used from A8parts?) and next time when you remove your RNS-D just change it.
Old 2nd November 2011, 04:45 PM
... or swap the one over from the passenger side, they're the same..
Old 16th November 2011, 09:43 PM
well its all working again thanks to the switch and i can confirm that my steering wheel is infact heated and comes on with my seat now thanks for the advice
Old 26th November 2011, 08:10 PM
Glad it is working now Guy.
Now we need to solve your water ingress problem and we're all set for RNS-E installation!
Old 26th December 2011, 08:10 AM
Yes indeed !
I have sorted the water ingress problem now its been sound now for about 5 weeks lots of rain and no water in the car ( Botangs hole )
