Old 29th January 2009, 10:18 PM
Default Whirring noise.
Car is a 99/V 'facelift' S8
There is a whirring noise from the ventilation system. I think it happens about every 10-15 secs.
Each cycle consists of two whirrs seperated by a short pause.
It sounds a lot like an autofocus motor on a camera and it repeatedly whirrs once-has a wee pause-then whirrs back. Sounds like a small motor is running.
What is wrong and how do I stop it? Quite annoying in such a quiet car.
Old 30th January 2009, 06:56 AM
Sounds like one of the AC vent direction motors is cycling. You may wish to invest in a bit of software called VagCom from Rosstech to diagnose problems like these. There is a freeware version that will diagnose the problem but not fix it.
A cheap lead of E-bay will do what you need although the full kit is the dogs danglys.
Alternativly ask on here with you location and there may be someone with VagCom nearby who will do a diagnostic.
Mike
Old 30th January 2009, 07:28 AM
I'm pretty busy until the middle of next week.. But could meet up to have a look later in the week.
Drop me a PM.
Old 30th January 2009, 08:07 AM
Aha!
Now I see what you're on about re vag-com!
Simon
Old 30th January 2009, 08:46 AM
harpersimon
Guest
Posts: n/a
as opposed to some ladys doctor?..
Defo sounds like the vent flap motor - I can hear mine moving if I alter things without the engine running, or when I shut off. Autofocus on a camera is a very good description!
Old 30th January 2009, 10:45 AM
Could well be the position motors for the flaps, but they usually click every 5/6 minutes rather than so often. Good news is, we have the motors, and they're not too tricky to change once you know which one is failing. Again, Vagcom may point you quickly in the right direction there...
Old 31st January 2009, 09:57 PM
After driving it for a few hours, this seemed to settle right down.
I think it's servicable!
