#41
On to the radiator this afternoon
'just needs a regas' yeah.... The condenser is utterly ruined and just falls apart to the touch so I just cut it off. I will remove the remains and salvage the hoses later on when I fit a new condenser. The radiator is also very deteriorated Red 'universal' ATF Cue biblical-plague levels of swearing. I guess I was right to treat the 'refurbished gearbox' with suspicion Assuming it drives ok, I'll do a few oil changes with Mannol AG52 to flush all this rubbish out before I pull the engine and box for the major service. When its out I will open it up and inspect the drums etc The back of the radiator is even more of a mess I cleaned up the front panel before fitting the new radiator - this will dry out overnight and go back on tomorrow. The engine is nice and dry at the front I was going to fit the missing subframe brace, until I realised the holes aren't there This is a PF subframe which has obviously been replaced at some point in the car's life, presumably since the original rusted out. This is pretty disappointing since when I first inspected the car I was quite pleased that someone had already blasted and painted the subframe. Never mind - I have spares. 36 hours. |
#42
As a matter of interest,the panels you swapped out ,is there a difference in colour ( assuming they had original paint)
Audi S8 D3 07MY 5.2 V10 Daytona Grey With Bang & Olufsen Advanced Sound System, Advanced Parking System, TV Analog/ Digital, Rear/Back Window blinds, Front and rear heated seats, Alcantara Roof, Extended leather Pack 2, Extended Aluminium pack, Carbon and Aluminium trim packs, RSE, PS2. Daily driver Audi A8 d4 2014 phantom black 3.0 tdi Previously owned Audi 80 1986 1.8 white Audi 80 1990 2.0 red Audi A4 1996 1.9 tdi green Audi A6 1.9 tdi 2000 blue Audi tt 225 2000 silver Audi s8 d2 2002 fe grey Audi a8 4.0 tdi d3 2006 black Audi a8 3.0 tdi d3 2010 black |
#43
Not that I can tell at the moment. They were original paint and the same age so in theory should be a perfect match, but I need to get the whole car polished to be sure, since its all quite dirty and matte. Once its shiny I can have a good look round it in daylight and make a proper assessment.
#44
Lots done tonight.
I made a new headlight level arm from scratch New radiator - I decided not to muck about with used ones since I had one in stock and its a pain to do so no point doing it twice. Front panel prepped for the new radiator I took the air intake duct off to get to the air filter and the throttle body boot just fell off The hose clamp was tight, but not actually attached to the throttle body. This might explain why it was intermittently very noisy when running (like an exhaust leak), which was puzzling me. The intake duct hadn't fared much better - there should be a metal ring in here to stop it collapsing when the clamp is tightened. Oh. There's the metal ring, jammed in the throttle body boot... Someone has mangled this bracket for the airbox, for no reason I can discern Pulled the airbox so I could get the screenwash tank out to investigate the pumps. There's nothing quite so vexing as getting the front end back together and then realising one of the pumps isn't working, and since the headlight washer pump was disconnected it was worth investigating Just... why? I have a donor car of the same colour so just replaced it Whoever had been fiddling had lost the clip for the screenwash connector I replaced this rotten rubber hose While I was in here I put a rivnut in this hole for the airbox trim Cleaned the screenwash tank and put it back in I had to break out the special fan pulley holding tool to have a look at the belts while the front end is off. The engine is very noisy which is usually the accessory drive on the front The fan bearing sounded like a bean tin full of marbles so that was replaced with a good used one. It'll get a new one eventually but this was to hand. All the timing gear is in really good condition, apart from these idlers which have suffered while the car was laid up. The belt is fine, the tensioner is fine, and the two main idlers are fine, so I'll just change these two idlers for now then it'll get a belt kit later. Good used idlers in place The front snub mount was also destroyed Shims removed and a new mount fitted The accessory belt is toast, as were the two rollers so these were replaced with good used parts, again just for now. Front end all done for now, ready for the covers and rad to go back on. 41 hours Parts used: PS hoses (refurb, £200) PS hose brackets (used) NSF upper rear arm (used) NSF lower rear arm (used) NSF wheel bearing (used) CV boot (£12) Suspension brace (used) Boot lid (£150) FE wheels (£500) Window motor (£50) Headlight level arm joints (£15) Radiator (£300) Belt idlers (used) Accessory belt & idlers (used) Snub mount (£60) Air filter (£6) |
#45
how much for the headlight leveler arm clamp?
#46
Are you putting the D2Doctor logo on these items?
Paul Gosport UK ________________________ Audi S8 2002 FE Avus Silver / Extended Red Leather. Daily Driver: BMW 3 series GT - Just more practical for my camping trips! |
#47
That clamp looks like a 3D-printer special.
As for the rest of it, there's a hint of "can I build a complete S8 from all the bits I've got lying around"...….
2003 D2 FL S8. Irish Green Pearl/Beige. Solar sunroof, auto-dim mirrors, electric rear seat functions, ski hatch retrofit; extended leather. Aftermarket DVB-T, reversing camera and full XCarlink (Bluetooth etc.). 2016 Volvo V40 T5 Cross Country (4WD) with ALL the toys including adaptive cruise etc. etc. Osmium Grey with Blonde/Charcoal leather interior. Polestar performance "optimisation". (A much rarer model than a D2 S8 by the way!) Oh, and a brand new engine at just under 30,000 miles on the factory one! Finally: gone, but not forgotten..... 1998 D2 PF S8. AgateGrey/Platinum. Every option (I think) except electric rear seats, tiptronic steering wheel, ski hatch, towbar & dimming door mirrors. e.g. Cruise control, NavPlus/TV, Bose, GSM, Xenons, Solar roof, Parking sensors, Alcantara/leather everywhere of course. (internal dimming mirror added later) 1998 (very early) Ford Focus 1.8 Zetec; ABS/TCS, Heated screen/mirrors, Aircon, Auto-dim mirror, Leather, Trip computer, Cruise control, OEM Ford SatNav with CD changer. And before that a lot of Rover 800s, a few oddities, a lovely Triumph Dolomite 1850HL with Overdrive and way back in my schooldays an Austin Seven aka Mini 850! |
#48
Yes, the clamp is printed hence the bright orange. Thats my prototyping filament since its much easier to see details in bright colours.
I'm not going to be selling these in the near future as I need to see how it holds up to regular use as it is in a very harsh environment. This is something I'll keep in the toolbox for when the metal clamps can't be reused. By the time the murple is back together I will have effectively built a complete S8 from bits I've got lying around, since the only things which won't have been replaced will be some of the glass, some of the purple panels and three of the tail lights Oh and maybe the fuel tank. Captain carnage doesn't appear to have been near that. |
#49
Sounds like a new edition coming up. The TBE......Trigger's Broom Edition
Audi S8 2002, Black (even the chrome bits) Audi RS6 Avant 2008, Daytona Grey Maserati Granturismo 2008, Metallic Nero Carbonio Audi S8 2015, Daytona Grey |
#50
I called it Trigger to a young Polish friend the other day and he was very confused until I explained it Three engines, two gearboxes, its had four sets of wheels mounted and hasn't even left the yard yet!
Thread Tools | |
Display Modes | |
