Old 22nd January 2022, 02:36 PM
Zip's Avatar
Zip Zip is offline
Question Crazy alarm: door sensors?
Hi. As I am driving at the moment, the roof courtesy light is pulsing on and off, as if it has detected an open door. When I close and lock the car, the alarm is now regularly going off. (Thankfully the siren isn’t working …job for another day!). If I then unlock the car with the fob, the interior light comes on, as you would expect, but when it fades, it is pulsing again, even with the car unoccupied.
I have a suspicion that the car thinks that the front passenger door is constantly open. This started happening after my elderly father decided to use his size 12 to push the door open, cracking the speaker grill This may be unrelated…
What can I do to check/replace? His doors the car know the doors are open?
Thanks,
Zip
Old 22nd January 2022, 03:09 PM
Any indication on the instrument cluster that a door is open?
Audi S8 D2 2002 88k mls
Old 23rd January 2022, 10:19 AM
Zip's Avatar
Zip Zip is offline
Well….yes. Offside rear showed up as open once….but wasn’t.
Old 23rd January 2022, 05:10 PM
Zip's Avatar
Zip Zip is offline
What should I be checking please?
Z
Old 23rd January 2022, 05:24 PM
The rear interior light can cause odd stuff to happen with all the interior lighting. Its made up of lots of bent bits of sheet metal clipped together and things can go a bit haywire when its gets bad connections.
Possibly the door latch itself which has a microswitch for open/closed.
The central locking module can be very difficult to troubleshoot unfortunately.
Old 23rd January 2022, 05:29 PM
+1
I fixed ALL of my weird problems with or related to that unit eventually by re-soldering all the joints on the little PCB inside it, several had failed to a greater or lesser extent causing all sorts of weirdness.
It drove me mad for ages, there's undoubtedly a boring thread on it here somewhere...….
Edit, here: http://forum.a8parts.co.uk/showthread.php?t=9097 Hope it helps.
