Old 28th May 2015, 08:58 AM
Dave McB Dave McB is offline
Default Wanted: ABS Pump
probably one for the forum sponsors tbh...
I need to recondition my ABS pump on the RS6. Its an inconvenience to have it taken off and sent away - we are stuck with a VOR (vehicle on ramps) until its done.
Ideally, if I can buy a used one, I can send that away to get it refurb'd and then I can take my old one off - meaning that I don't hold up a ramp for a week.
Part number I need is 4B0 614 501AC (or AD) - Bosch number from unit is 0265 225 167(or 169)
Anyone have one FS?
Old 28th May 2015, 09:55 AM
Anyone have one FS?
You could try A8 Parts Dave, they often have these 2nd hand as a complete unit - its important to change both the ABS block and the ECU not just part of it, and to use a pair with the same codes as your current ones
Old 28th May 2015, 10:38 AM
AFAIK I thought the whole unit came as one piece - hence the post with the part numbers.
Il have a further look into that first
Old 28th May 2015, 10:39 AM
theres a sticker on the ECU part with both numbers and then a number stamped on the ABS block which should match one of them on the sticker
