Old 7th August 2018, 10:40 AM
RICKY D's Avatar
RICKY D RICKY D is offline
Default Need a favour - wheel to arch measurement please
Can someone do me a favour and take a measurement from the centre of the wheel to the edge of the wheel arch front & rear please?
Needs to be on standard sport/S8 suspension and preferably on 20’s but 18’s will be fine as the diameter is quite close.
Thanks
Rich
2016 S5 Coupe Black Edition - Ibis White
Old 7th August 2018, 01:59 PM
Front about 380mm
Rear (presently unloaded but with about 3/4 tank fuel) is closer to 370mm.
(standard S8 suspension and FE 20s)
Old 7th August 2018, 05:13 PM
RICKY D's Avatar
Thanks Mark that’s perfect
Old 8th August 2018, 10:01 AM
55stars 55stars is offline
We know what you're doing... Wind them right down!
Audi S8 D2 - no leaks, no creaks, 9x20's, solar sunroof... more to do
MG Maestro 2.0efi - dissolving on the drive
Old 8th August 2018, 10:24 AM
RICKY D's Avatar
Old 8th August 2018, 12:36 PM
pete-p's Avatar
pete-p pete-p is offline
Just be sure to lower the front more than the back! Something all 8s seem to have a problem with.
Cars...
Old 8th August 2018, 12:58 PM
I wouldnt wind them too far down - I lowered mine at the front with coilovers and had to dial them back up slightly as it was too easy to rub wheel arch liners and also too easy to catch the front bumper on kerbs and speed bumps.
Where I've got it now suited me as it doesnt do either and accommodates all of the different wheels
ID:	19891   Click image for larger version
ID:	19892   Click image for larger version
ID:	19893   Click image for larger version
ID:	19894   Click image for larger version
Old 8th August 2018, 01:14 PM
I wouldn't wind them too far down
Neil, yours being a 3.7 did it start at the same level as an S8 would, or does fitting coilovers cancel any differences anyway?
Personally I have enough trouble with kerbs due to the (standard) S8 low front to not want it any lower at all.
Old 8th August 2018, 03:51 PM
It was a Quattro Sport so already at the same height as an S8 spring wise.
The rears have stayed as QS rear springs and shocks as I couldnt get the coilover kit on the rears and still accomodate the 10.5" x 21" Khan Rear Wheels
Old 13th August 2018, 05:54 PM
RICKY D's Avatar
Ok coilovers are on.
Fronts both measure 340mm which equates to a 40mm drop. There’s still quite a lot of thread left for additional lowering.
Offside rear is 340mm whilst the nearside rear is 355mm which equates to 30mm and 15mm drop respectively. Both the rears are on the lowest setting which is strange Is the petrol tank siutuated more to the drivers side on these?
