Old 18th February 2014, 01:19 AM
Jesus...I'm sure it's driving you mad.
It MUST be that bloody connector !!!
Old 22nd February 2014, 12:53 PM
mannyo mannyo is offline
did some more investigating today and I have come to the conclusion that it must be the sensor thats dodgy.
This is the fault in VCDS
Address 76: Park Assist Labels: 4E0-910-283.LBL
Control Module Part Number: 4E0 910 283 HW: 4E0 919 283 A
Component and/or Version: Parkhilfe 8-Kan H07 0030
Software Coding: 0101008
Work Shop Code: WSC 02313 785 00200
1 Fault Found:
01629 - Sensor for Parking-Aid; Front Left (G255)
004 - No Signal/Communication
Freeze Frame:
Fault Status: 01100100
Fault Priority: 3
Fault Frequency: 1
Reset counter: 50
Mileage: 209212 km
Time Indication: 0
Date: 2014.02.22
Time: 11:20:34
Clearing the fault it goes away again, until you engage the sensors. The fault is always the same sensor.
Now the error is a bit of a red herring because the car is seeing the sensor, and the measuring blocks confirm this. However the readings coming from are wrong, looking at measuring block 007, the reading for the sensor is half what it should be compared to all the rest of the sensors both front and rear.
Code:
4E0 910 283 		Parkhilfe 8-Kan H07 0030
	Group A:	'007
		Front Left	Front Left	        Front Right	        Front Right
TIME	        Sensor	Center Sensor	Center Sensor	Sensor
Marker	 ms	            ms                    ms	        ms
0.01	         0.56	            0.96 	            1.04       	0.94
0.15	         0.56        	    0.99	            1.04	        0.94
So looks like it needs a new sensor, now to work out the part number and how to remove this sensor without removing the bumper.
Manny
Past
Old 23rd February 2014, 09:09 AM
Something tells me that taking left wheelarch off will allow you to change this sensor without taking the bumper off. Or possibly taking off left fog light???
Old 23rd February 2014, 01:06 PM
I can reach in from above, and get right to the back of the sensor so access is no problem. Getting the thing out is more the issue. I have no idea how its retained, or how I would get a screwdriver down there to release the connector.
Now, if the trim beneath the headlights came out easily it would be a doddle to change.
Manny
Past
Old 23rd February 2014, 01:39 PM
If you have enough room from the top, connector shouldn't be a problem, simple plug and actual sensor looks like needs just a twist and pulling out
http://www.ebay.co.uk/itm/Audi-A6-A8...item27d30fc811
If not enough room, then access from the wheel arch might be your another option as mentioned before.
Engine under tray out and access from the bottom???
Old 23rd February 2014, 02:29 PM
I found a brand new genuine OEM sensor for way cheaper than the A8parts used one (Sorry guys).
http://www.ebay.co.uk/itm/3210477522...84.m1423.l2649
Sometimes brand new parts are cheaper than used. Not really fussed if its not silver, as long as it works.
Manny
Past
Old 23rd February 2014, 03:05 PM
Link was just to show the connector type and the way it's possibly fitted (twist and pull, I think)
Old 26th February 2014, 10:59 AM
I now have the sensor from the link I posted, Genuine Audi part for much less than the dealer. its going in my bumper unpainted for now as I just want the sensors to work, in the future I'll sort out the paint. I just hope its the sensor and not a wiring break.
Manny
Past
Old 1st March 2014, 02:38 PM
Hooray, my parking sensors are working again.
Bit of pain changing the sensor but got it done.
There is a wiring loom that sits directly behind the sensor, so had to cut a tie wrap to move that out of the way.
Once that was done I was able to locate the clips holding the old sensor in place and then pop the old sensor out.
Removed foglight grill, and the foglight and got the sensor still connected to the loom to the foglight area, and disconnected the plug.
Plugged in new sensor, and tested. Then pushed the new sensor back into the bumper and reassembled everything.
Now have three silver and one black sensor in the bumper, but they are working....
Manny
Past
Old 3rd March 2014, 11:48 PM
Finally !!!
Great stuff Manny, so good to now this nightmare is finally over
Change the other corner one to black one and you wont even know it's not the way it should be
