Old 25th November 2009, 04:24 PM
sutherland sutherland is offline
Default GPS Antenna
I've lost my GPS signal due to an open circuit to the GPS antenna. I cannot find any obvious problem in the accessible connections at the boot or head unit. Is there another common place that a break occurs?
Old 25th November 2009, 05:37 PM
Have you taken the antenna itself out to check for a break on the circuit board?
Old 26th November 2009, 11:34 AM
No. Do you mean dismantle the boot mounted thing and inspect it?
I guess I could test it by removing it and pluging it directly into the RNS unit.
