Old 6th July 2015, 06:05 PM
ScottD3's Avatar
ScottD3 ScottD3 is offline
They look nice mate.
I like them.
[center]
06 3.0TDI Quattro:
Options:
Old 19th October 2015, 11:02 AM
Conquistador's Avatar
Only problem I encountered was when I offered the refurbished wheel up to the hub to fit the bolts. Because there is now an extra few layers of paint, it was a very tight fit slotting it onto the centre of the hub. Had to take a razor blade to the inside of the hole and scrape some paint off and very slightly increase the bore so it was a comfortable fit. Perhaps they should have masked the centre hole as well as the bolt holes when spraying?
And the above post clearly isn't the last I'll have of this problem...
Tried to remove the wheels yesterday to put the 18" S8 wheels back on for a few months as they have new winter tyres, and these 20"s are practically welded on!
Any tips on how to remove them? Trolley jacked the car up then tried gradually winding the jack of death against the wheel to pop it off, but nothing.
Currently '8-less
Previously:
- D3 A8 3.0 CVT
- D3 3.7 V8
Old 22nd October 2015, 09:48 PM
ScottD3's Avatar
Rubber mallet and smack it!!
[center]
06 3.0TDI Quattro:
Options:
Old 22nd October 2015, 10:19 PM
47p2's Avatar
47p2 47p2 is offline
Back to the car and kick the tyre on the outside, if that doesn't work a block of soft wood (white pine or similar) and a 4LB mash and hit the inside of the rim.
Whatever method you choose ensure the car is securely supported before you apply brute fore to remove the wheel
Nite Blue 3.0L SE Quattro
Old 22nd October 2015, 10:35 PM
If the usual kicking, thumping etc doesn't work slacken the wheel nuts off a bit then go for a wee run round a car park flicking steering left and right till you feel it free off.
Disclaimer I'm not responsible if it goes horribly wrong
Old 23rd October 2015, 01:28 PM
Norretal's Avatar
Norretal Norretal is offline
Just noticed this by chance
Audi TT - 2015 - Ultra
Old 23rd October 2015, 01:30 PM
Johnmed's Avatar
Johnmed Johnmed is offline
+1. If all else fails, do what he said!
2007 Mini Cooper S R56
Old 9th November 2015, 01:41 PM
Late update on this. Found a sturdier trolley jack and kicked the tyre a few times with no mercy, didn't fancy trying it with the little Halfords trolley jack I have or the jack of death that comes with the car.
Lesson learnt, ensure future wheel refurbishers mask the centre bore hole and stud holes!
Currently '8-less
Previously:
- D3 A8 3.0 CVT
- D3 3.7 V8
Old 9th November 2015, 01:58 PM
47p2's Avatar
Some Copper Slip round the wheel bore centre and hub will prevent then seizing. A thin spread will be fine and won't splatter out when you drive
