Old 9th January 2020, 01:02 PM
Default No Longer Wanted (single 20" D2 FE diamond cut alloy wheel)
Does anyone have a single 20" FE wheel for sale? The D2 size, not D3.
Ideally with a good diamond-cut face, not painted.
One of mine has some bad pothole damage and has been repaired once already so I'm looking at options.
Old 9th January 2020, 01:36 PM
I think Neil had a brand spanking new 20" FE for sale a while back. Perhaps try sending him a PM if he doesn't see this post.
Old 9th January 2020, 02:08 PM
I think Neil's was a D3 one which is 1/2" wider, but I'll check if he doesn't reply here.
Old 10th January 2020, 09:18 AM
The "Brand New" D3 one ended up being a D2 one, but has gone to TinTin now, but I still have a couple of FE D2 Spare Wheels at 8.5mm, need to check if they are diamond cut or not (I suspect not so may need doing)
Old 10th January 2020, 11:01 AM
Thanks Neil, let me know what you have.
The potential problem with refurbished/repainted ones is that underneath the coating they may well no longer be suitable for diamond cutting.
I've handed over my damaged wheel to a specialist repairer and await their opinion after taking the tyre off and examining it in detail.
My spare wheel (currently on the car) is "sort of" diamond cut and could potentially be "revitalised", so I have some options.
Old 16th January 2020, 04:55 PM
So, they have been busy and only just looked at it today.
Apparently the tyre is damaged too, so I'll need to get a new one. But the wheel is repairable.
Given the spare is a different design tyre (the slightly older MPSS) I'll probably buy a pair of new MPS4S's and retire whatever is the worst current tyre to be the spare.
That way I'll have two brand new and two fairly new MPS4S's on the road and a worn MPS4S as spare.
As for the wheels I'll see what the repaired one is like, I might consider having the spare diamond cut again and move the one with most cosmetic marks to be the spare.
At the end I will also probably have a part-worn 20" MPSS available. I got it originally from Adrian and have only added a handful of miles so it's still good for a spare at least. Will need to check the date code.
Meanwhile I'll dig out one of my winter wheels (haven't fitted them this year) to be the spare while all this shuffling takes place!
Old 20th January 2020, 04:42 PM
Collected today and the repair looks good, ought to for the price!
The damage to the tyre is a bit odd, a strip torn out of the beading on the outside, could possibly have been done on a kerb or metal edge. The repair place said they really didn't want to refit it and it probably wouldn't be safe for high speed road use.
But I'll keep it in the garage as an "emergency spare" as otherwise it's good and only buy one new tyre for now.
Old 22nd January 2020, 02:00 PM
...… and only buy one new tyre for now.
Fitted today, so all back to normal though still on summer wheels and tyres.
I might just swap onto my winter wheels now and put the 20s back on as late as May so they're tip-top before the annual meet.
MPS4S's are really good when it's warm, even in the wet, but earlier today (just above freezing) on a damp twisty road in a heavily wooded area my right foot managed to "inadvertently" trigger the ESP warning at around 40mph.
So hopefully I no longer need another alloy, but if you do happen to have one spare get in touch...………..
Old 22nd January 2020, 02:23 PM
I'd never leave my Michelin summers on my S8 or Model S after November - though I agree about swapping them back on as late as May Winter PA4s are much, much safer on any winter surface, whether that be snow, ice, or just colder road surfaces. I was in a Model 3 performance on Monday afternoon, shod with MPS4S's, and it was much more jittery than it should have been. Winters all day long between November and April for me.
Old 22nd January 2020, 02:52 PM
Me too, normally. It's just that with the warmish weather (mostly), the various issues I've had limiting use of the S8 (and my regular mobile tyre man going bankrupt!) and other factors keeping us busy but not driving much I haven't bothered this winter. So far....
PS My S8 winter tyres are currently Pirelli Sottozero, I think I saw a post saying you had those on one of your stable, just not sure which. (Volvo now has Michelin Cross-Climate all year)
