Old 20th January 2018, 04:22 PM
Well, not sure what to suggest.
So you're saying that when you first start the car, the drivers door mirror goes very dark, but the rear view is ok.
But you stop the engine. Disconnect, and reconnect the main battery, restart the engine and the drivers door mirror is then ok ?
But the rear view mirror just never darkens at all ?
There is a light sensor in the rear view mirror that connects directly to the roof module - this tells the roof module how bright the car is behind, and then there is a wire running from that module back into the rear view mirror, and canbus will be used to send the signals to both front door controllers, which in turn will generate the required voltage on the wires to the door mirrors.
Its possible there is a fault / connection issue with the rear view, whilst it still sends perfectly accurate signals to the doors.
The fault on start up is weird. Without looking at the measuring blocks between the roof controller and door controllers, its difficult to see what the controllers are attempting to do.
It could all boil down to a simple short inside the drivers door. If the passenger mirror glass were auto dimming, it would tell us a lot.
I'm so not convinced its anything to do with the battery. Temperature and conductivity, quite possibly.
I started a 4.2 Tdi earlier with most of its glow plugs faulty, and it exhausted pretty much the whole battery before it finally fired after a minute plus.
... and it still didn't have any issues with any controllers, even when the dashboard was visibly dying under the voltage drop.....
If you want the auto dim to work, you just need to find the root cause and fix it. Botching around it will only make things worse in the long run.
Old 21st January 2018, 01:04 PM
erubus erubus is offline
Not quite. on first start, the driver's mirror goes dark and the rear view stays clear but does not auto darken at all. When battery is disconnected and reconnected, the mirrors work perfectly as they should.
The passenger side mirror doesn't do anything as a PO has replaced it at some point but just got generic plain glass mirror, no auto darken or heating.
It has only ever started to do it since I had all the problems with the hot start issue and it was getting jump started every day for 6 months. The battery seems to be iffy at best anyway although I do need to do a test on it.
A battery was coded to the car when it was new sometime last year, but it has been swapped for a different one and back several times so I'm not sure which one is coded to the car. I'd been told that the coding was only for the battery level indicator on the MMI (on this forum) I take it that this isn't the case.
Finding the root cause is unfortunately the sticking point.
Daily drive: 2008 A8 4.2TDi
2003 A8 4.0TDi. 4 zone climate, double glazing, Bose - dead
Other cars: 1980 Land Rover Series 3, 2.25d, hydraulic winch,Van/station wagon/topless depending on my mood
1990 Land Rover 90 factory county station wagon with all the luxury additions, such as a clock and a tape player.
2007 A4 3.0TDi s-line cabriolet quattro
2000 A8 D2 2.8 quattro, looking for a new home - gone
2003 A6 3.0 quattro, in the way... anyone want any parts? - gone
Old 21st January 2018, 02:41 PM
I managed to find a measuring block in VCDS roof module for Automatic day/night interior mirror, block 003. Light sensor signal status: invalid Mirror dimming value: 0.5%
Door mirror is not dark, so I presume the system would be working correctly (It's daylight ATM).
Roof module is not registering any fault codes.
Old 21st January 2018, 04:39 PM
I can confirm the mirrors operate as they should with the "invalid" status described above.
Old 30th January 2018, 07:19 PM
update: I swapped the battery for the one out of one of the Land Rovers at the weekend and fingers crossed, touch wood etc etc the mirrors haven't done their thing since.
If it lasts a month or two I shall get a 900-1000CCA AGM battery that I can actually code to the car. The battery from the Landy is only 850 CCA and is a yuasa which I cant code to the car - it is fairly new though and has never been discharged so it's in good nick. It needs to be to turn over a 40 year old Land Rover diesel.
Still not going to number my poultry but looking good so far.
