Old 25th April 2017, 10:18 AM
For me it was temperature related. It would fail the first time it was moved after a cold start, but then once the engine was warm it would be fine for the rest of the day.
Yep - that sounds familiar. Only ever happened to me when (a) it was cold and (b) hadn't been used for quite a while. No issues when without conditions (a) and (b) together, and not recurred since before I mentioned this in my previous post on this thread.
Old 13th August 2018, 01:04 PM
Been for a local drive, all seems well so far and absolutely no hint of hesitation, but only time will tell. Fingers crossed.
Note to self; Go and clear the old error codes - NOW!
Well that was less than 2 years ago and today, for the first time since, a scan (pre-MOT) has shown:
01119 - Gear Recognition Signal 35-10 - - - Intermittent
At least I know not to panic...……
Old 13th August 2018, 05:04 PM
Regulus Regulus is offline
As if it will not do with only one issue, eh?
At least you can use the car while waiting for an opportunity to fix the problems
Johannes
_________
A8 32V engine
Jeep Grand Cherokee -98
Old 8th March 2021, 03:07 PM
Good write up MJ. Definitely a good alternative to the Audiworld methodology. As you said though, with all your new bolts etc in place it does make it a bit easier.
The combo of the ratchet spanner with the Torx bit is a neat solution rather than grinding down the Torx as per Audiworld,
Sadly, I'm having to refer to this write-up again, as Herman has been throwing a PRNDS fit intermittently, and just before Mark's funeral, which couldn't be worse timing .
Here's hoping it's just the contact terminals that need a clean-up, particularly as this unit was only replaced with a new one in 2017
Old 8th March 2021, 03:39 PM
I cleared an F125 fault on car that had be stood for a while by putting the gear leaver through all it's positions repeatedly but gently at speed. Worth a try if the codes point to the F125 switch.
Old 8th March 2021, 03:50 PM
Thanks Mike, no VAGCOM here, so can't guarantee it's the F125, but i'm pretty sure that's the case. It was persistently showing this for three days in a row, even with gentle persuasion, which I've not had before. Then it cleared yesterday, and I took him for a good 20 minute drive then, making sure I exercised the 'box without thrashing it, but now it's back again, so I've left him with my local (trusted!) mechanic to see if cleaning the contacts helps.
Old 8th March 2021, 09:16 PM
Stephen, I have VCDS.
Old 16th May 2021, 06:50 AM
goldsax goldsax is offline
I think I may have an F125 issue.
when I put it into D nothing happens.
when I press the accelerator, the car thuds into gear...
PRNDS is the only option displayed.
feels like it then starts in 2nd gear, possibly limp mode, seamless gear changes,
reverse not an issue.
I have seen the threads re. the F125 removal and replacement, but want to check the connector first.
is checking the connector something the can be done 'easily' ie without the removal of brackets, mounts etc ?
does F125 have a part number?
many thanks
Audi S8 2002
Old 16th May 2021, 07:43 AM
Thats a mechanical problem unfortunately, not F125. It'll be going in to 4th gear and not changing.
If it still drives in limp mode then its likely either the first clutch drum thrust bearing, or the o-ring in the same assembly rather than a broken drum. In terms of gearboxes, thats relatively straightforward to repair since its all just behind the oil pump. Getting the gearbox out is more of an ordeal than fixing it - not a driveway job but something which could be tackled by an advanced DIY-er.
Old 16th May 2021, 08:34 AM
many thanks for your reply.
I am happy to do fluid, brake etc changes but gearbox removal is something I would refer out..
as per your diagnosis, is this something I need to seek the services of a gearbox specialist ?
thanks again for your guidance
Audi S8 2002
