Old 1st September 2017, 08:33 AM
lackovicj lackovicj is offline
Default rusted noise
Hi
When I floor the pedal I can hear rusted noise(like screwing rusted nut) for 1/2 second.
Anybody have an idea what could be?
A8 d3 2003 3.7 petrol
Thank you
Old 1st September 2017, 09:18 AM
Conquistador's Avatar
Check the kickdown switch behind the pedal? Might be loose or broken.
Currently '8-less
Previously:
- D3 A8 3.0 CVT
- D3 3.7 V8
Old 1st September 2017, 09:36 AM
HI
Thanks for a reply I will check the kickdown switch.
It sounds more like from underneath of the car,,,between the engine bay and transmission. Is very hard identify where is coming from or just record the noise.
Noise in a level of : rpms between of critical and over-critical rpms, kind of resonating or as i said screwing rusted nut on the screw.
It does not happen when pressing the pedal slowly,,only while flooring the pedal firmly.
Thank you
Old 1st September 2017, 09:46 AM
Originally Posted by lackovicj View Post
HI
Thank you
Possibly propshaft CV joint when put under the strain of a kickdown?
Old 26th September 2017, 10:57 AM
Kick down switch operating as normal.
not sure about the CV joint as the noise appear even when cruising on 50mph and then just floor the pedal..1/2 second of noise and thats all.
I might not be correctlty describing the noise i getting.
If someone lives around SE/Lewisham I can pop in and floor the pedal for you.
Audi A8 D3 2003 3.7 V8 petrol, Oyster gray with black interior
19" alloy, Sport suspension transmission and seats, HID headlights, Phone in armrest, 4zone AC, Sat-Nav, TV, Dimmable exterior mirrors, VCDS
Previous : Chevrolet Blazer 2001 LT 4.3 petrol
Old 26th September 2017, 12:11 PM
Very long shot, but can it be low on gearbox fluid ?
If so, it can cavitate under acceleration and the bubbles in the oil make a brief whistling sound.
It would be more prominent when cold, and would happen at idle revving in park as well as when driving....
