Old 12th July 2021, 02:20 PM
ulfilias ulfilias is offline
Default Can Gateway 0019 mistake - coding
Hi There,
On Friday there were BIBLICAL rains in Peterborough. I drove home, parked up, dashed for the house door and that was in.
Saturday we went for a drive on going round one of the estate roundabouts we got dripped on. I found water in the cupholders and went back and dried things off. The stereo was somewhat erratic and the roof lights kept turning on!
Later i ran the heaters for a while and hooked up my ODB11 to clear faults and see what was happening. I thing i mistakenly agreed to auto coding!
Sunday we did another short drive out. No satnav, stereo etc. The screen flips up at start says no traffic info then closes.
I think the auto code thing has basically deleted my sat nav, tv tuner, radio and media player1 (now a GROM-MST4, which may be part of the issue) - I've a scan from early on in the car, with the long code.....also the various other data, but it doesn't seem to want to accept the coding, yet is saying there is a fault with the coding - This is via VCDS is this a Security code thing and if so ANY tips oh how
The autocode was FDFE7FDC1B3500
Address 19: CAN Gateway Labels: 4E0-910-468.lbl
Part No SW: 4E0 910 468 HW: 4E0 907 468 A
Component: Gateway H07 0070
Revision: 07 Serial number: 16003049161CE4
Coding: FDFE7FDC2B3504
Shop #: WSC 00640 210 83262
VCID: 65C629BBAC726116CE-8030
Well.....with a little effort i've now got the coding reading the same. - Using the 210 & 83262 though the wsc of 00640 was greyed out!
However it's made NO difference. I can now see the modules in VCDS list but none of them connect. Nor are they working!
I've checked a load of fuses, checked the optical MOST bus and there's the red laser light on the connector to the GROM. The nav CD player flashes red when i hit the button in the boot and VCDS optical bus check see's everything, but the media player because it's the GROM!
The centre console round the gearstick does NOTHING, but the car starts/stops on the button.....It's all a bit strange!
Current :
Previous :
Also :
Old 13th July 2021, 03:27 AM
mcs's Avatar
mcs mcs is offline
Originally Posted by ulfilias View Post
Hi There,
It sounds like you have affected the control head ECU.
I would simply try and redo the control head coding to suit your car, and see if this brings it all back to life. Then code the remaining MOST items one by one.
The start stop button is not part of the MOST system which is why it works.
04 A8 - 4.2 Sport
Indigo Leather Sports Seats - Sports wheel - Sports Air Suspension
Auto Boot - Double Glazing - AMI - Solar roof
TV - Bose - Voice Control - TPMS - AFS- TINT
Power Blind, Fingerprint - Light package (in and out)
Retrofits:
OEM Auto headlights & rain sensing wipers
OEM Bluetooth phone
Bluetooth Audio Streaming
Reverse Camera
OEM Aluminium Package
Auto boot close using remote/door button
Old 13th July 2021, 09:13 AM
MCS - Yeah....There's obviously something coding that's still wrong.
I popped the MMI buttons out yesterday. Surprisingly easy actually. One screw under under the ashtray, takes that part out and then the whole thing with the trim pops out. Little gearstick movement and a lot of cables to pop out but actually a 5 min job.
I managed to take it all apart and clean the board and the Start/Stop and Parking Brake are separate units!
There's an odd big heavy plug in 2" bar under there too. Key stuff i'm thinking?
Looked at the board, cleaned it with isopropyl alcohol and it actually looked fine
Quite how i code the head is the question now....I'm guessing clear off the can gateway anything it doesn't want and then see if just that module is accessible ?
My other idea was to try and pop the old CD player in and see what that does. I just have to find it
Current :
Previous :
Also :
Old 13th July 2021, 03:02 PM
Tried the old CD player. Needed to swap a connector to get it back in, but no REAL joy.
I can now do the optical scan thing and get all OK on Electrical and Optical.....but the can gateway is still NOT playing despite coding and seeming fine.
NONE of the system seems to be doing much. There's power to the CD player and Nav, though they don't show up, nor the control head, sound system, radio and TV.
Control electronics 2 has a test function, doing this rolled the display up and i quit. On starting the car again i saw the audi MMI splash screen, then traffic info for a few seconds and it dropped back down again!
On starting the car this morning i also noticed a CD Empty flash in the cluster screen but that was about it!
Tried running the car with the MMI buttons disconnected, just in case there was a stuck button type error. Nope!
Current :
Previous :
Also :
Old 14th July 2021, 11:02 AM
So far NOTHING i've done has made any difference, doing a search on the MMI and issues brought a few interesting bits.
https://www.audiworld.com/forums/a8-...2835919/page6/
Similar issue, long thread, down at the bottom it mentions the Phone was the problem, also says corrosion and water and right location!
https://www.audiworld.com/forums/a8-.../#post24817841
Has some interesting stuff. A bit of test pressing buttons with the CD player out, which should be easy
I'm now wondering about the phone???
" the initial logo should be there because the MMI HEAD has two paths of communication it communicate via MOST and CAN. see photo below, so with the MOST down the screen should trigger for a few seconds then blank because it switches over to MOST after the init wakeup via can or MMI PAD which in your case is dead.... its not doing that the head or can lines is dead, I seriously doubt its the can lines...
7 of the 13 wires in the head is a direct connection to the MMI PAD E380
the rest is power mute for Telematics and can."
I'm getting that MMI turn on....strange that the MOST test in VCDS seems to say all good though
Current :
Previous :
Also :
Old 15th July 2021, 11:18 AM
I tried pulling the battery for a while. I now have an incorrect clock and date. Surprising how you miss the settings options!
Despite the VCDS MOST test returning everything fine on both optical and electrical, on normal and -3db, I've bought a paid of terminators to the optical bus. ~£7 on ebay.
It seems a cheap and useful thing to knock things off the ring loop and IF it's the phone, I can just delete it. I've not used the phone in however many years of having the car and the old tesco sim that came with the car seems to have died anyway. I used it once to call my mobile to find it
I'm thinking, find the head unit in the glove box area and terminate there and see if i get the screen back!
For this weekend away I ordered a nice Soundcore motion+ and will borrow the GFs sat-nav. I'd take the PA painted jeep but it's a warm one and i'd like the nice aircon. Besides having a decent travel speaker for the cottage will be a bonus
Current :
Previous :
Also :
