Old 20th June 2018, 09:05 AM
Conquistador's Avatar
Default 'Telephone is not installed'
Always had my phone paired with the car in the past, I got a new phone a few months ago and just never bothered to pair it because the signal is shocking and too sketchy with the reflective glass, but I went to pair my current phone (Android Nokia) recently and got this message on the Telephone screen.
Thought a module was fried or something but get no errors relating to the phone when scanned with VCDS.
Anybody seen this before or know how I can ever pair my phone again?
Currently '8-less
Previously:
- D3 A8 3.0 CVT
- D3 3.7 V8
Old 20th June 2018, 09:14 AM
Chip2786 Chip2786 is offline
I had this on mine when I bought the car, lift the carpet on the passenger side and open the black plastic box. Unplug the big chunky cable for a few seconds and then reconnect. Made mine work
Jobs done so far;
Fitted an RS Steering Wheel, Fitted 15mm wheel spacers, Lowered 10mm with VCDS, Reinstalled factory DVB, Unlocked VIM, Updated MMI to 5570, Fixed Factory Bluetooth Phone, Fitted heated fan-spray washers, Installed Bluetooth DAC For Audio, Added projection Puddle lights, Wind Deflectors, Fitted Apple TV to all 3 Screens, installed car WiFi, Fitted Custom vortex Exhaust
Old 20th June 2018, 09:17 AM
Sounds promising.
Any idea what the 'big chunky cable' is though?
Currently '8-less
Previously:
- D3 A8 3.0 CVT
- D3 3.7 V8
Old 20th June 2018, 09:28 AM
Sounds promising.
It’s power and mic etc for the BT phone module
Jobs done so far;
Old 20th June 2018, 09:55 AM
Certainly my interpretation of that message is that it thinks the phone interface module is missing. Does it appear on the VCDS scan and can you communicate with it?
Old 20th June 2018, 10:07 AM
Mine would attempt connection but failed every time
Jobs done so far;
Old 20th June 2018, 11:17 AM
The MMI believes the module isnt installed....
Its possible, but unlikely you can talk to it via VCDS... If you can, then maybe unplugging and replugging might reset something, but I think its a long shot.
Due to its location, if you have a A/C or sunroof leak, its one of the first modules to get soaked.... then people remove or loop them out rather than coughing up for a new module at Audi money...
Old 20th June 2018, 04:57 PM
I managed to get a used BT Module for the RS6 for around £150 IIRC from ebay, needs the seat out to fit on mine though not sure on the S8
Old 20th June 2018, 05:02 PM
Shouldn’t be a seat out jobby, I can get to mine with it rolled back
Jobs done so far;
Old 20th June 2018, 09:11 PM
homer simpson's Avatar
Are these cars OK to disconnect the batteries to or is there a chance the electrics can play up? I know they probably throw up ghost faults but that's not a problem. If they are safe to disconnect then I would perhaps try that first?
