Old 30th April 2016, 06:07 PM
ColinR32 ColinR32 is offline
Default Height calibration problems
So i have put the lowering links kit on my A8, i have now tried to recalibrate the suspension but when i input the reading into channel three it keeps coming up invalid constantly no matter what i do, and now have a constant orange light on in the car and a fault as the badic setting has not been done but how do i get it to accept the third channel?
Daily Driver- Audi A8 3.0TDI D3 Mmi 2g high
reg- A8CPX
installed- bluetooth, hybrid dvbt tuner, aux input, finger scan, soft close boot,suspension lowering links
Old 30th April 2016, 06:16 PM
I don't know specifics of D3 lowering but it is either links ore doing it through VCDS, there is no need to do both.
Old 30th April 2016, 06:22 PM
Was doing it as i had been told the previous owner had messed around with it
reg- A8CPX
Old 30th April 2016, 06:50 PM
richardracer richardracer is offline
Default Suspension calibration on D3
Hi Colin,
I had problems doing mine. The technique with VCDS is very specific and is on the VCDS wiki.
Open controller, select channel 1, allow it to go down then up until it reads something like ready. Then put in value as measured. Press test then SAVE. Move to channel 2 and repeat including save. When all 4 wheels done, you need to put value (1 from memory) into channel 5, test then SAVE again. Only then will light go out and may need fault to be cleared.
You cannot miss any wheel and have to follow the sequence from channel 1 to channel 5.
I was missing out the save, worked for first 2 wheels, but gave invalid on channel 3 or 4 and light would not go off. I put standard values in first to prove it was all ok, before then redoing measurements second time around.
Good luck
Richard
2006 Audi S8 V10 Now Sold. Akoya Silver with black/grey leather, standard 20" wheels, hybrid TV, Bang & Olufssen audio, Heated seats front and rear, Dension ipod integration, DAB radio, keyless entry, rear electric blind, bluetooth connection to Apple iphone6S. Started at 60,000 miles end April 12. Now 171,500 miles as at Oct 2017. Now sold to fellow forum member.
Old 3rd May 2016, 12:59 PM
Got the bottom of the problem folks-
When i was fitting the rear shortend links the arms on that the links fit on to were attached the wrong way round, (me not paying attention again)
So i took the links of the sensor side, flipped them 180 drgrees and hey presto all is good aswell as no warning lights and all heights work on the mmi
Top tip: take pictures when taking things off 😂😂😂
reg- A8CPX
