Old 1st May 2019, 03:11 PM
Default Update
Huzzah! Hopefully the 01119 code is just from using Tiptronic like some cars seem to do.
Worth checking the state of your brake pads with the fluid that low - it has to have gone somewhere
Ok.had the car today in to check the brakes, change brake fluid before going to a performance driving session at knockhill (present from son/daughter) and there was a slow leak on rear nearside hose connection to caliper. Just needed tightening up. So that seems to solve the question of where the fluid went.
Old 1st May 2019, 06:48 PM
Glad it was an easy fix mate, and you need to keep an eye on your fluid levels more often. You should know better, dip the tanks!
Old 8th November 2019, 02:13 PM
Versace Versace is offline
Guys I’m having the same problems, ABS Light every couple of months, if I hit a pothole. But i get the hickup from the tranny when starting from standstill, it just bangs into first gear let’s say 2-3 times out of 10 starts. What could this possibly be? My brake fluid ist on max, brakes are okay... Why is the tranny acting up? The trans module has 0 errors, and the trans has always been serviced. Other than that it changes gears seamles!
S8 D3 FL II.
Porsche Cayenne 958 Turbo
BMW E83 X3 3.0d M-Sport
Old 8th November 2019, 08:53 PM
27litres's Avatar
27litres 27litres is offline
Does the transmission hard shift into 2nd under heavy acceleration?
How's the fuel economy?
I'm thinking MAF.
The ECU and TCU work together to give smooth shifts.
The MAF is vital to the ECU for this as it gives information on engine load and torque based on throttle position and airflow.
When my MAF went I got a very bad shift 1st to 2nd under heavy acceleration.
Marty
____________________
2002 Audi S8 - Project
Family:
2009 Volvo XC90 V8 R Design
Sold:
1997 Audi A4
Old 9th November 2019, 11:22 AM
HPsauce HPsauce is online now
My money is on 2 separate problems here. The gearbox is quite likely a worn F125 switch. What exact codes are coming up anywhere on a VCDS scan?
