Old 2nd October 2014, 03:38 PM
OMG, be careful with those ramps!
Old 2nd October 2014, 04:21 PM
Dave McB Dave McB is offline
Coincidentally - my 'trade' discount is only a few quid more than Adrian's 10%
Iv not found another supplier as of yet - my company has an account with ZF but are only allowed to buy certain things.
Im quite friendly with Mackies tho - if they can get the flange & seal im sure I could arrange a discount of sorts.
Old 3rd October 2014, 09:48 AM
Originally Posted by Mikey-S View Post
Just in case it's been missed, I have a brand new flange for sale in the classifieds. The updated design to incorporate the new seal. Let me know if you're interested.
Well having coughed up silly money for a new flange, it appears mine is also the revised part! Either from the factory (most likely) or before I bought the car at 8 years old and 40k miles.....
Mate just rang me to confirm he'd compared new and old and could see no difference in the machined area - he was about to pop the old seal out to confirm that's got the extended lip on it.
Bit galling as having ordered it from TPS I don't think they'll take it back, unless their ordered in parts policy is based on stuff coming from Germany rather than Milton Keynes. Guess I'll find out when I try later on!
Old 3rd October 2014, 02:47 PM
Adrian, I'd suggest to replace both flange and seal anyway. Because old one is already removed it won't cost you any labour and will give you additional peace of mind there was no wear on old flange which may has leaked because of that...
Old 3rd October 2014, 03:04 PM
Hi Sergey
It's been back together since before 12 today - the old part was inspected and the sealed surface is as new. My friend who works on the car said it basically looked no more worn than the new one.
I have kept the new flange and will see if it has fixed the problem before I return in - on the basis that the labour to do the gearbox oil change and replace the seal was £80 if it means going in there again it's only going to cost me £40 or so in time plus another seal if needed.
I have my suspicions that these seals are actually quite old and been stored for years in less than ideal conditions - it would at least in part explain why some people seem to suffer issues much more quickly after a seal change. The seal that came out of the car was intact, but obviously destroyed in the removal process.
Will put some miles on the car on Sunday driving to Slough to race toy cars so if the remaining surface oil has burnt off by then it should be possible to confirm whether the seal is now oil tight. Despite the smell of oil and the length of time it was leaking there was still plenty of oil in the centre diff, I'm told.
Old 3rd October 2014, 05:31 PM
Mikey-S Mikey-S is offline
I've done around 150 miles since I changed my seal, today when the car was on the ramp I had a look at the seal again and it's completely bone dry. The seal I fitted was very pliable, definitely not old stock. If yours does spring a leak, there's another trick you can try, you can pop the spring out of the seal, unscrew the part where it's joined then snip a couple of mm off it. Screw it back together then reinstall the spring into the seal. This will marginally increase the force that the seal puts on the shaft and the chances are you will have a more reliable seal. I've used this method a million times and it always works.
Old 8th October 2014, 08:36 AM
Yes, can you let me have the part number please?
Old 8th October 2014, 09:27 AM
It's the same one I've got listed on the 1st page - if you're in no desperate rush to get the car back I'd allow the garage to remove it first and check the seal and flange design. It seems late cars may well have left the factory with this modified part fitted.
An extended lip to the seal will also confirm this, as well as the additional machining in the flange to give that lip somewhere to sit
I plan to get mine up in the air next week to check the seal has done its job - if so I'll return the flange I bought to TPS - it'll cost me 15% surcharge, but that's less to lose than selling it on, I suspect
Old 8th October 2014, 09:53 AM
Sure. The part number is: 01V 409 809A
And photos can be seen here: http://forum.a8parts.co.uk/showthread.php?t=8844
Old 8th October 2014, 10:57 AM
Thanks, I'm going to check this afternoon and get back to you.
UPDATE: Sorry to mess you about - Mackies told me it was on back order yesterday, but today they said they'd ordered one and it should be in tomorrow.
