Old 15th September 2014, 05:10 PM
andycaca andycaca is offline
well...that didnt work!
next thing is to remove the boot lining and check the connection behind the cd stack/tv tuner...maybe tomorrow morning weather dependant...
Old 17th September 2014, 08:23 AM
little update.
i pulled the passenger side boot trim off and found the gps connection there. its all good.
so conclusions to be drawn:
1. there is an internal cable break somewhere
2. the RNS unit itself is broken
3. the GPS antenna is faulty
i have previously been able to pick up accurate GPS on the RNS when i took the antenna apart a couple of weeks ago, it worked sporadically for a couple of hours. since then, nothing. so i reckon the RNS is working OK with the signals (when it receives them!).
Old 18th September 2014, 09:00 PM
Quick update from my phone. GPS seems to be working, the satnav is showing correct location and 8 satellites. The problem was with the connector on the antenna tail, the wire was loose going into the connector so not making good contact. A bit of fuse tape to hold it in place temporarily and a test drive tomorrow around Norfolk will prove or disprove the fix
Old 19th September 2014, 09:36 AM
ScottD3's Avatar
ScottD3 ScottD3 is offline
Nice.
Easy fix?
[center]
06 3.0TDI Quattro:
Options:
Old 19th September 2014, 10:56 AM
Good news!
Old 19th September 2014, 06:05 PM
Easy enough I reckon! Drove about 100 miles today and the satnav was faultless. I will make the fix more permanent by crimping or shrink wrapping the wire securely into the connector.
I couldnt have done it without the help and advise I found on this forum 😁
2001 S8 D2
Old 19th September 2014, 06:08 PM
You're presumably aware that the antenna is powered by a voltage supplied up the cable from the RNS.
As such it's extremely important that not only are the connections good on both core and sheath, but also that there's no short circuit.
Old 19th September 2014, 07:58 PM
I figured it was an active unit judging by the onboard circuitry, the repair job is well wrapped with fuse tape but I will do a proper repair job and insulate it. Thanks for he confirmation
2001 S8 D2
