Old 28th May 2017, 09:31 AM
Spanker's Avatar
Spanker Spanker is offline
The second function "sort of" works on my D2. By "sort of" i mean that sometimes it works properly and sometimes it doesn't work fully. Like it will drop the windows and open the sunroof but will then only half close them or it will do it but only in stages! Its like a mind of its own.
On my blue car, with everything shut, when the OPEN button on the fob is pressed and held, the windows only will open all the way down. But the sunroof won't open.
When all the windows and the sunroof are open, a continued press of the CLOSE button of the fob will close everything.
Not tried the red car yet. Doing that now
Dean
Old 28th May 2017, 10:01 AM
Mine works the same as yours. Maybe the Close feature adds the sunroof as well since you are essentially locking the car, so best to try and close everything.
Old 28th May 2017, 10:08 AM
Spanker's Avatar
I think that too.
Tried the red car and it does the same.
And after an up/down of the windows, the one-click feature works a treat too
Dean
Old 28th May 2017, 11:34 AM
Yup all works as expected here. And I had a flat battery recently.
After a battery failure/swap I "thought" the only things you need to do are the radio code and window auto up-down. Others settings (e.g. auto-lock etc.) are retained.
And Spankers list is all normal D2 functionality, including the pathetic alarm horn I'm afraid. The rest are settable with VCDS.
