Old 10th July 2011, 03:36 PM
Tony,
Thanks for the link. I wonder if this is the one. I'll give them a ring tomorrow.
Old 10th July 2011, 04:59 PM
tonyt102's Avatar
tonyt102 tonyt102 is offline
No worries.
That's the one, works a treat.
Old 10th July 2011, 09:19 PM
Amanda Amanda is offline
can I ask why you are bothering with the parrot when you can actually have the aud blue tooth unit fitted?
Old 10th July 2011, 10:09 PM
I understand the audi bluetooth unit won't work with RNS-D, it can't be voice controlled and it wont play my SD cards with all my music on.
I would love to do an RNSE but I am a elecy wiring pygmy.
Old 10th July 2011, 11:28 PM
the rsn-d is dated seriously dated your best option is the rsn-e that will give you full hands free as long as the audi bt module is installed and it is a an easy upgrade with both the bt unit And the rsne
Old 12th July 2011, 08:01 AM
Mike, geninely, the RNS-E retrofit is easier (and far better documented) than the Parrot install you're attempting !!
I did an extensive thread on it, which will make it a piece of, er cake
Old 12th July 2011, 10:28 AM
RNS-E has voice control and it works for everything, including Bluetooth phone.
Voice control comes with RNS-E software. If RNS-E unit has been supplied without voice control (different part numbers), there exists a modified software for pre-2010 units which will enable voice control on units without voice control. This is what I did with my unit.
To actually activate voice control you'll need to press PTT (Push To Talk) button. It's on your MFSW. If you don't have MFSW there is a solution called CANGATE. It is basically a box which will inject PTT button CAN bus message into CAN bus each time you press your custom button. For instance, it is possible to retrofit "headrest retract" or any other 'missing' button into the dash and connect it to CAN bus via CANGATE. This will allow voice control via that button without having to retrofit MFSW.
Old 12th July 2011, 11:18 AM
It's honestly not hard in the slightest. This parrot thing makes no sense to me but the RNS E was a piece of cake and one of the best mods I've done. More or less plug and play.
Old 12th July 2011, 11:46 AM
Could it be done in a day on somebody's drive that just need beer to make them work?
Old 12th July 2011, 11:50 AM
It takes longer to cut the faceplace down to size, than it does to plug it in and make it work. The leads that come from Kufatec make it literally, plug and play.
There are only two connections that would need soldering up for the canbus, and thats not a desperate rush as most things work without that....
Defo less than a day, unless you give them too much beer
