Xenon range module
Hello guys
i'm having a problem with the Xenon range module on my Audi A8. ( 4L0 907 357 ). Bought it from internet, but i cannot locate it...? Where can i find it ?
commander sildenafil 100 pfizer 100mg www.viagrasansordonnancefr.com |
http://forum.a8parts.co.uk/attachmen...3&d=1420367344
Behind the instrument cluster
Del |
Re
Oh, that is the last place where i did not looked for it ! I have open everyghing, B pillars, glove compartiment, under steering, etc.
So i need to remove the instrument panel, to find it ? I hope will be there Thank you gents !!
Re
Right. Found the sensor, replaced. But still same problem. The scan it said about the right headlight motor, i tried the connections, all looks ok. Could be the motor or the sensors on the suspensions ? Where can i find the suspension sensors, and how to check / acces them ?
Thanks
Why don't you post a copy of the scan so we can see what's going on,
If you had level sensor issues it would effect both lights not one, so my feeling is you actually have a problem with that headlight
Del |
Still the same problem ( i have attached the photo. It may be the motor inside to the headlight ? how to check that ?
Can you post a picture of the main screen when you open Xenon Range window [55] please.
Also if you could attach the full scan in a form of txt document please Also could you check the fuses 43 and 44 on the main fuse carrier on the passenger side. On each headlight connector pins 1 and 2 are for the headlights motors. They go back to the xenon range module behind the cluster as you know, pins 18 and 19, then pins 2 and 3 from the module go to can separating connector above the fuse box. Pins 4 go to fuses 43 and 44 mentioned above. Pins 14 on each headlight are earth. I guess if fuses are fine, especially the one for the side in question, they are 10A btw, then you could check resistance on each cable, between the module and headlight end. Providing as much informations would only help and speed up the process of finding the issue
Any of you have these for the 2006 Q7 4L? |
if you find anything on your travels it would be great to have it added. If your needing stuff in a hurry then pay for access to Audi erwin for a day and download everything you can for Q7 If not so much of a hurry you can go through the pain of downloading Elsawin and installing it.
Del Last edited by Delboy; 29th July 2015 at 05:43 PM. |
