Old 28th April 2016, 05:08 AM
you can put the battery level back with vcds
BT is refering to the factory bluetooth telephone not a bluetooth music device
ok,
so your on 5150, you can stop there or continue
im not going to object to Julians reasoning on disk numbers, this has been around for yuears and rumours and info gets passed about and changed
you could do it manually and untick the bose before continuing
if you get CP its a trip to Audi and a few quid, not that big a deal unloess you get an idiot garage who havent a clue what your talking about
Old 28th April 2016, 10:58 AM
A8Pete A8Pete is offline
OK, so now I have v5150 installed I wanted to initiate the hidden green menu. I have gone into VCDS inot [07], then [10] adaptation, the entered channel 08, rwad the value which was 0. I then eneterd desired value of 1, test, save, then done go back.
I went back into VCDS and checked the store value of channel and it displayed 1.
However when pressing "car" and "setup" together the hidden menu doesnt appear.
Have I done something wrong? Do I need to reboot the MMI in some way?
Old 28th April 2016, 11:07 AM
yes reboot the system first
Audi MMI force restart procedure – 2G & 3G
Locate button: SETUP button. big control knob. upper-right soft button.
Press and hold those button at the same time.
After two seconds release buttons. Audi MMI screen will go black for few seconds and system will reboot.
sometime you have to try a few times to get in the hidden menu
Old 28th April 2016, 11:10 AM
OK. I have rebooted twice. On my A8 that was "tel", big control knob, upper right soft button.
Then to try and access the hidden menu I press together the Car and Setup buttons at the same time and hold for a few seconds? Is this correct. It's not working for me.
Old 28th April 2016, 11:15 AM
A8P's Avatar
A8P A8P is offline
Press setups and hold just before you press and hold car. Not both at the exact same time. This might help.
Audi A8 sport 3.0tdi Quattro, 19" wheels, 2tone leather, rear camera, heated seats, ami, Bose sound system, dab, xenon adaptive headlights, 4 zone climate control
Old 28th April 2016, 11:17 AM
I hold down 'Car' first then together with 'Setup' and wait.
Matt
Old 28th April 2016, 01:34 PM
Finally got it working.
Press "Car+Setup" (car slightly ahead of setup) together until hidden menu appears, took about 5 seconds on my car
Then scroll down to Diag Settings and press enter
Then scroll down to Car Menus Maske and press enter
The find Battery Level and press enter
Scroll down the the bottom and press Accept Changes
Press the return button 3 tmes to return to the front screen
and ten the battery level indicator is back under car>system
Thanks to everyone. Much appreciated.
Where do I enable AV inputs?
What other wonderful things can be done under this hidden menu?
Old 28th April 2016, 02:30 PM
you should now be able to do the inputs with vcds as i wrote earlier in the thread
or
in hidden menu
under telephone
APK 0×01, 0x0B, 0x0C
Stereo Aux In -
i think
