Old 5th January 2016, 08:46 PM
ScottD3's Avatar
ScottD3 ScottD3 is offline
Default Parking Lights. How?
I parked up this afternoon in an area where parking lights would have been good.
Flicked the indicator to the correct side, turned the engine off, locked up and walked away.
No parking lights.
Tried again with the lights off and auto but nothing
On other vags I did the above and it worked fine.
Am I miss something here?
[center]
06 3.0TDI Quattro:
Options:
Old 5th January 2016, 09:09 PM
Sidelights on and indicator on???
Old 5th January 2016, 10:05 PM
ScottD3's Avatar
Yup.
[center]
06 3.0TDI Quattro:
Options:
Old 7th January 2016, 01:48 PM
Mine works in Auto - all I ever use is Auto and I use the one-sided parking feature a lot.
It also gives the beep and lights on message on the DIS when exiting the car.
Something must be wrong or the car had been recoded incorrectly.
Old 7th January 2016, 01:52 PM
Have you ever coded your car for scandinavian lighting or american lighting etc scott? might be that possibly?
Old 10th January 2016, 12:03 AM
ScottD3's Avatar
That's a good shout.
I know I've played about with them before.
I'll take a look tomorrow.
Has anyone got a copy of their coding to hand?
[center]
06 3.0TDI Quattro:
Options:
Old 21st January 2016, 07:42 AM
I can confirm scandanavian coding doesn't affect them as I use that betweek october and march to make the rear DRLs come on.
Address 09: Cent. Elect. Labels: 4E0-910-279.lbl
Part No SW: 4E0 910 279 Q HW: 4E0 907 279 Q
Component: ILM Fahrer H14 0230
Coding: 0143121
Shop #: WSC 02313 785 00200
VCID: 3668AF7D415C5C3
Subsystem 1 - Part No: 4E2 910 113 B
Component: Wischer WWS D3 H50 0420
Coding: 00000037
Shop #: WSC 02313
Subsystem 2 - Part No: 4E0 910 557 Labels: 8K0-955-559.CLB
Component: REGENLICHTSENSORH11 0050
Coding: 00205084
Shop #: WSC 02313
Igniters ON --> VCDS ON --> [09] Central Electronics --> CODING --> change the LAST DIGIT to 2 (Northern Countries, Sweden, Finland, Norway) --> DO IT --> Exit Controller --> DONE
Old 26th January 2016, 07:31 PM
ScottD3's Avatar
Thanks SD.
I'll take another look this week.
[center]
06 3.0TDI Quattro:
Options:
Old 12th February 2016, 04:59 PM
Conquistador's Avatar
What does changing the last coding digit to '3' (USA) do? I'm out in the US at the moment and seen D3s and D4s that flash the red outer rear brake light units as indicator signals as a pose to using the standard amber lights which we are used to. Can this be coded or is it a different type of lamp for the US cars?
Currently '8-less
Previously:
- D3 A8 3.0 CVT
- D3 3.7 V8
Old 22nd October 2016, 05:31 PM
aTOMic's Avatar
aTOMic aTOMic is offline
Both my 2004s work as described for single-side marker lights, but neither has DRLs enabled. My understanding is US coding calls for H7 high beams at reduced power as DRLs, if so someone must've changed something...
One car is a very early "2004" (last VIN digits are 011XX, built March 2003 IIRC) but i doubt that has any bearing, since D2s had the same functionality.
-Tom
I'm in love with a car.
2004 4.2L Petrol A8L
Sage Green/Black (one of only five D3s thus colored sold in the US)
