Old 30th April 2019, 05:48 PM
homer simpson's Avatar
Default Front Brake Rattle
This is now doing my head in! Audi removed and refurbished the caliper, put it all together and it seemed ok. Due to health I haven't really driven it but yesterday I went for a drive and there is a rattle from the same caliper when going over an uneven road. If I apply the brakes, it stops. This rules out the shield (which I have checked).
Could this be pads not seated correctly or the caliper pistons causing issues? I will call them tomorrow but I would rather have sorted it myself if it was a quick job rather than booking it in etc. Perhaps the pads need some anti-seize or anti-rattle lube if there is such a thing?
Old 30th April 2019, 06:26 PM
I've had that on a few occasions, after having new discs/pads fitted, when the mechanic failed to properly re-insert the pad retainer spring (or whatever it's called). On my D2 that is of course, but I'm assuming D3 calipers are similar.
If the spring clip is inserted incorrectly, such that it's not pressing against the pads, they rattle around until you hit the brakes. It's a surprisingly loud and tinny rattle too. I thought I had a loose exhaust mounting the first time I heard it.
Old 30th April 2019, 06:52 PM
Thanks. This was my first asumption and it may well be the cause. The spring-plate does seem to be fitted correctly (as per Tech Dump) and can only go one way. I wonder if they bent it a bit to make it easier to fit hence losing it's tension? It also makes a clicking sound when stationery if you pump the pedal (when you let go) so does sound like the spring is U/S.
Old 20th July 2019, 12:56 PM
Update on this, it was the pads not sitting correctly due to spring not fitted correctly (although they seemed correct). Took it back to Audi and they sorted it.
Old 20th July 2019, 03:51 PM
H-M3 H-M3 is offline
That’s very poor of Audi.
Audi A2 1.4 petrol 2002
NO VCDS rely on Neeldub
Old 20th July 2019, 06:53 PM
That was the least of my problems. I have had 3 separate issues caused by them but I can say that they did everything they can to put it right and keep me mobile. Yes it was the least they could do but I didn't have to fight with them, they apologised and did the work correctly. Outcome was
1. O/S caliper refurbished
2. N/S caliper refurbished because the paint didn't match (I only paid for the seals and extraction)
3. Brake rattle fixed
4. New locking wheel bolts as they gunned them up so tight it broke the key!
It doesn't give them a good reputation but the service advisor and his manager were both spot on so I can't fault them. Had it been another garage, I may have had to fight them to resolve it all and they would not have done the other caliper or provided a loan car.
Old 20th July 2019, 07:18 PM
That’s good they sorted the issues, hopefully they have sent the guys for further training.
