I've ordered, well garage did, oil from TPS base on VIN or number plate, can't remember, but basically they've send the same oil which was put in the first place in the factory, and again, if you don't experience serious issues, and can't really travel hundreds of miles to ZF guys to do it, then stick to like for like to avoid mixing different oils, but listen what the other guys are saying as they are more knowledgeable and experienced on this subject than me
So I was under the car today to take pictures of the ZF identification plate on the gearbox. Here's the plate on the gearbox.
Here's my build code sticker. So I have a JAY gearbox, but code sticker says I should have a JNL... Am I missing something or has this car had the gearbox replaced?
A8 D3 3.0tdi quattro 2006 A6 C5 1.9tdi 2004 A4 B5 1.9tdi quattro 1997 |
pp
A8 D3 3.0tdi quattro 2006 A6 C5 1.9tdi 2004 A4 B5 1.9tdi quattro 1997 Last edited by tipptop; 3rd May 2015 at 09:07 PM. Reason: Double post |
So after further digging:
http://www.thectsc.com/index.php?p=p...=184&parent=58 If you look at the fluid reference table in that link it has the 6HP19A in two sections and specifies either lifegaurd6/G055005 and lifegaurd8/G060162. It says 'trans part list dependant', not sure what that means. Maybe this is the difference of software required. Dealer and etka say lifegaurd8/G060162. Why can't it just be easy
Drained a small bit of fluid today.
[IMG][/IMG] Definately not the blue Lifegaurd 6+ fluid, but hard to tell if its lifegaurd 6 or 8. Definately filthy dirty, slight yellow tinge at the edges. http://www.apra-europe.org/dateien/d...chatronics.pdf The colour of the 3 lifegaurd fluids are shown in the above link, along with the proper fluid change procedure. Lifegaurd 6 is proper yellow and Lifegaurd 8 has a yellow/green shade. http://www.zf.com/brands/content/en/...ange-kits.html Anyway, I've contacted ZF directly and will wait to see what they say. Their parts list for an oil change kit linked above also specifies Lifegaurd 8. So I will see what they say as regards a software update.
This is the reply I got from ZF.
The following solution has been found for your request: Hello The only way to be certain about the oil is to speak with your local Audi dealer and have it checked against the VIN. http://www.zf.com/global/media/en_us...s/TE-ML_11.pdf is the link for ZF oils in passenger cars. If you get an oil part number from your local Audi dealer you can reference it to the list and this will tell you if it is life guard fluid 6 or 8. If it is life guard fluid 8 then you must get the software checked and updated if needed. So looks like the only choice is to book into Audi.
Ive added the ZF PF to the section sticky at the top of the thread for future reference so thanks for that
Confidence is the feeling you have before you know better . . . . Audi A8 D2 3.7 Quattro Sport 1999 FL - Melange 2nd Place Winner - A8-Freunde Annual German Meet 2012 at Edersee 20" x 9" Bentley GTC Wheels with 385mm W12 Front Discs & Bentley Caliper Covers, Front Lowered on Coilovers, Xenons, Combined DRLs and LED Foglights to modified OEM front fog lamp position, Alcantara/Leather, Full Black Alcantara headlining + pillars and blind shelf, Bespoke Flat Bottomed Sports Steering Wheel, Dark Myrtle Wood, Autodim Mirrors, Bose, Blinds, Digital TV, Ski Hatch, Modified rear exhaust section for extra V8 Burble Audi S8 D2 Final Edition 2002, Avus Silver with Red Leather Interior Tiptronic with Sport mode button, Sony rear entertainment package, Bose sound system, Audi Navigation Plus, 20 inch Final Edition alloys, Full Cat Back Stainless Milltek exhaust, giving a great V8 burble Audi A8L D2 4.2 Petrol with LPG - Ebony Black Audi A8L D4 FL 4.0T Petrol twin turbo - Havana Black Audi A2 1.6 FSi Sport - Dolphin Grey with Votex body kit and Red Leather Interior and some other A8's A8L's and Mercs |
I am recently joined member, having purchased a 2007 Audi A8 4.2FSI a couple of weeks ago...... C |
Just to add, I also just called my local Audi centre who gave me the following part nos. for:
Gearbox ATF: G060162A2 9 litres Diff: G052145S2 1.1 litre They couldn't even give me the spec of those oils..... C |
Gearbox ATF: G060162A2 9 litres = ZF Lifeguard 8 (green)
Diff: G052145S2 1.1 litre = A synthetic 75W90 I used http://www.opieoils.co.uk/p-982-fuch...-gear-oil.aspx as it has the friction modifier for Quattro already in it. It can be used in all 3 diffs. The last two digits of these part numbers is usually the size of the bottle so may vary. Last edited by snapdragon; 5th January 2016 at 02:17 PM. |
