Old 24th May 2015, 09:08 AM
Johnmed's Avatar
Johnmed Johnmed is offline
Default Voice activation
Just wondering if I'm missing out on something. Does anyone use this in their D3?
I've tried it once or twice, and it seems convoluted and slow to the point of unresponsive. In fact I've only used it when I've hit the button on the MFSW by mistake!
2007 Mini Cooper S R56
Old 24th May 2015, 12:34 PM
The 2G one is definitely clunky. The 3G version works far better, but I still don't use it
Old 24th May 2015, 01:05 PM
Johnmed's Avatar
Cheers. That's what I suspected.
Old 24th May 2015, 03:31 PM
I use it a lot on the 2G, the 3G is better, but 2G is still OK for a ten year old car.
You can say HELP for the possible commands...
e.g.
RADIO HELP
MMI HELP
CD HELP
I had the car 3 years before adding voice tags to contacts.
The contacts need to be in NAME, not NAVI. It's is all a bit confusing.
I also turned of voice feedback so it doesn't for example say CD after I say CD.
Old 24th May 2015, 03:36 PM
I have had no luck with mine, if i say call it says cancel
Old 24th May 2015, 03:40 PM
tipptop tipptop is offline
I only use it for the nav. Thats about all its actually useful for while driving
A8 D3 3.0tdi quattro 2006
A6 C5 1.9tdi 2004
A4 B5 1.9tdi quattro 1997
Old 25th May 2015, 11:48 AM
My only use is "stop navigation" which works fine.
I have on occasion used it to entertain passengers, but they usually can't resist joining in, then it all goes to pot.
Old 25th May 2015, 11:51 AM
Lee S Lee S is offline
I have a 3G car and mine works just fine. Have programmed name tags and use "Call - John - Mobile" and it works great. Also for "Radio" or "Media", etc. It's OK, but not perfect.
Lee
2017 Nissan Leaf Tekna
Old 25th May 2015, 07:01 PM
I hardly used I in the a8, but the a7 system is much better, recognises names in contact list and is fairly quick.
Old 27th May 2015, 12:16 PM
Do you know what, after 3.5 years I am getting into it more.
Today I have been using the
"Special Destination" command
It then asks something like" The type of special destination please"
Then I say "Shopping Centre" or suchlike off the special destinations list - it's not the sort of thing you know off the top of your head unless you have used the NAVI for a year or more.
