Old 7th June 2011, 06:04 PM
Default USB CD Replacement Thingy
I promised someone I would post this, but clearly it must have been after having too much salad as I dont remember who now, anyhow whoever you are and assuming you did not have as much salad as me and you remember, here you go here
Audi S8 2002, Black (even the chrome bits)
Audi RS6 Avant 2008, Daytona Grey
Maserati Granturismo 2008, Metallic Nero Carbonio
Old 7th June 2011, 06:48 PM
I cant remember if it was me or not as I had too much salad too
Old 8th June 2011, 06:22 PM
That's what mine has got fitted as well - not very impressed with it tbh, especially for ipod integration, which basically it doesn't!
Instructions are handy though as didn't come with mine
Old 8th June 2011, 06:40 PM
I was just going to use a card or usb stick as I dont have an ipod, and it sounds like you can then use it just as you would your cd only you have 99 tracks per cd, have you tried it with just a card or usb device?
Old 8th June 2011, 07:22 PM
I fitted similar one to friends 2003 A4. Works OK, he is using USB sticks. Some head units or maybe all can have 2 changers connected so You can keep existing one along with this USB thingy. You make 6 folders( or 10) on it and up to 99 songs in each. You control it like a CD changer, each folder acts like virtual CD.
Old 8th June 2011, 07:33 PM
I started buying SD cards to go in my RNS-E, which doesn't require the CD 1-6 folder setup anyway and has the same SD only (no SD-HC cards) limitation, but both require you to convert ipod happy tunes to MP3 format, so I've ended up creating 2 copies of any music I want to install that way.
Would be much easier if I could control the ipod directly via the RNS-E interface, but that would require a different dock interface as this one requires you to use the actual ipod to control it. It just emulates 'CD5' playing constantly so nothing happens if you try the RNS-E controls.
If this one still allowed the CD changer to stay connected, I'd be happy enough. There's only 1 changer control on the back of the RNS-E. On my A6 there's the double DIN Symphony head unit with built in CD changer, so wouldn't be surprised if that had another CD out option. I have a spare one in the loft so may have to dig it out to check. If it does I might pull this out of the S8 and get a proper ipod dock interface.
Old 8th June 2011, 08:31 PM
Ahh yes sorry Adrian, forgot you had the "E"
Old 8th June 2011, 08:33 PM
yeah thats what I was going to do, my unit only has 1 cd connection but wouldnt need the CD changer anyway if I had this
cheers
Old 8th June 2011, 10:15 PM
They all have only one connection but some allow daisy-chaining 2 CD changers. I do not remember exact details but when I put the one in for a friend it had instructions how You go about keeping CD changer. I remember when pressing Mode button it would circulate between Radio-CD(or cassette)-changer1-changer2. He did not have changer so not tested in real life.
Old 9th June 2011, 07:34 AM
Night Train's Avatar
If its anything like the Dension 100 & 300 (which I use) the manufacturer does an optional CD retention kit which I've used (wiring harness) but this will handle a hard disc also...
Other vehicles
Oh Yes....... The '98 PF S8!
