Old 5th February 2016, 05:26 PM
My exhaust needs doing really soon, I have rattling cats. I really want a X-pipe but worried about its placement, worried if it will create drone, and if it will be the correct shape to release more HP. A badly made X-pipe with rubbish cross-section merger will probably rob HP so its a real risk.
I think any reasonably made x-pipe will be better than factory H-pipe overall but H-pipe might deliver a bit more torque at low rpm at certain scenarios. There is no such thing as best x-pipe for all conditions, it's a compromise. Pipe size, location, entry and exit angles as well connecting cross-section will determine at which rpm it will increase torque more. If you want to make it simple and generalise then steeper angle and closer to engine will increase high rpm torque and max BHP at cost of low rpm torque. Shallower angles and further from the engine will give more low end torque at cost of max BHP.
Old 5th February 2016, 06:52 PM
and none at at sounds really good but I have no idea what it does to power
You could make the new system so that the x section is independently removable, then you can play with different styles and see what it does.
Old 5th February 2016, 08:15 PM
That's the usual wisdom of X-pipe vs H-pipe (that X-pipe surrenders some low end torque).
However the one I have been looking at that was developed for Porsche 928 seems to increase torque across the whole range.
http://www.performance928.com/cgi-bi...ss_parent=1128
But on the other hand will it work well with Audi's 4.2 V8? How different is the 928's V8 from the Audi V8? who knows.
I would think any X-pipe works better before the cats, not sure that the cross-over can pull the gasses from opposite bank as well through the mesh of the cat. I'm not sure if there is enough room in the D2 to put it before the cats.
I'd have to disagree about the sound Mikki, I had a x-pipe on my previous S8 it sounded gorgeous. Also just check out some of them on youtube, they sound very good.
https://www.youtube.com/watch?v=QbaSAxgxtPc
https://www.youtube.com/watch?v=nqrufMqTQpY
Old 6th February 2016, 01:33 PM
I'm not saying an x pipe doesn't sound good, just that no x also sounds good
This isn't the vid I wanted, but it'll do.
https://www.youtube.com/watch?v=mANtLFlyYrw
I tried open downpipes with my old V8 too. Thats also interesting
Old 7th February 2016, 09:00 AM
Yup that sounds pretty damn good
You inspired me to find a no-exhaust video
https://www.youtube.com/watch?v=N26o9C5OBY0
found a better one, wow this is amazing!
https://www.youtube.com/watch?v=KkglRtuqDt8
Just chopping out the rear box sounds amazing too!
https://www.youtube.com/watch?v=SYLUfVVCkb4
Old 7th February 2016, 09:09 AM
Yes it does, I've done that on my D2 and it sounds awesome - deep boomy v8 when driving and like that video you linked to when you floor it!
Old 13th March 2016, 08:47 PM
YorkshireBloke's Avatar
Hi,
On my previous LPG car (V6 Vectra) I removed the CAT as LPG clean enough to not need it.
Sound improved no end...
Robert
