Old 25th August 2015, 10:52 AM
irelandbuyer irelandbuyer is offline
Default Rattle on start & Error P0391 Cam Shaft Sensor
All,
Wondering if this has happened here before.
Car was rattling on cold last week, was OK when it warmed up. Nothing else for the rest of the day.
The following day, the Emmissions Light came on so I brought it to my local independent who ran a diagnostic and it threw up the following fault:
"Fault Code: P0391/Cam Shaft POS Sensor.Bank 2"
We're going to swop this to the other side and see if the problem follows it and if so, then replace the sensor. Hopefully it's just a sensor but the concern of the technician is that this is actually a deeper issue with the timing chain and he feels it's an early warning that something else is amiss..
I read elsewhere that you can see from the readings if the timing chain is elongated?
Wondering if anybody has heard of this fault code etc?
Cheers.....
Old 27th August 2015, 02:47 PM
Originally Posted by irelandbuyer View Post
All,
Cheers.....
Which engine , petrol , diesel ...... does it have variable timing control cams
The rattling maybe suggests stretched timing chain so yes you would get the code you have .
To check the cam /crank synchronisation with out a strip down you need to scope cam and crank signals and compare to a known good waveform trace .
Thinking about it if in the data blocks you have relative cam angle to crank , yes you could see from this if the chain is stretched
Old 30th August 2015, 11:51 PM
matt matt is offline
When you say rattle on cold for how long.
I only ask as my 4.2 petrol 06 d3 has just started rattling for about 3 secs when its not been run for a few hours.
Only had it a few weeks, Seems like i Have a few issues under the hood that have just developed. have to top up water every 3 days. The guy must have had a good way of disguising faults as they didnt do it for the first few weeks lol.
Gonna trawl some threads and see if i can diagnose
Old 31st August 2015, 08:48 PM
Very often the rattle from cold for a few seconds is a stretched timing chain , the hydraulic tensioner has to wait for the oil pressure to fully extend it , the 3 second rattle is the time it takes to build the oil pressure .
Also check that it has a genuine or at least a good quality oil filter , if it's a spin on filter they have a one way membrane on the filter inlet , this is there to hold oil pressure in the oil filter to help with the no oil pressure from start scenario .
Old 1st September 2015, 09:04 PM
This was my thought thanks for the second opinion.
I am going to do an oil and filter change i think.
It sort of coincides with an oil top up i did.
Never trust the guy at the car shop lol... maybe i topped up with wrong oil perhaps.
Old 2nd September 2015, 10:13 PM
Yes try the oil and filter change , but if it still has the start up rattle looks like you may be in for a much bigger job I'm afraid
Old 3rd September 2015, 11:56 PM
appears to be coming from the rear left of the engine looking at it from the front.
Its been quiet again for the last couple of days. Just done a throttle linkage fix, Started it up and it sounded worse than ever, lol.
I dont have time to do it myself so looks like I will have to find someone around the North West with a decent reputation. Not taking the 8 to a back street novice lol
Away all next week but I may tackle it myself when I get back if i can get an hour or two on my mates ramps.
Old 14th September 2015, 09:16 PM
One or two hours on your mates ramp to do a timing chain ..... wow !! you da man ! 😀
Old 21st September 2015, 11:49 PM
sorry that was a mis type, I meant i could investigate if i can get some time on the ramps lol, im good on the spanners but not that good lol
I am actually leaning more towards hydraulic tappet noise now. It all coincides with me topping the oil up with what the shop told me to put in. I threw the bloody bottle so cant remember what it was. Not like me but i was in a rush at the time.
First step oil and filter change this week but every post I read someone says different oil Please...... what oil goes in the 4.2. I know that i have to use the genuine filter as the cheaper ones dont have the non return in them.
im actually considering booking it in at Audi Warrington to get it done. Dont believe i said that. it will defo be a first lol
Old 22nd September 2015, 01:05 PM
Burnzybubbles's Avatar
Mann filter from Ecp or gsf should be oem and have the return valve.
