D3 - Retrofit Bluetooth to Replace Fixed Handset
** Edit See page 7 for photo references **
Guys, Just replaced my fixed Audi/Motorola phone kit with the bluetooth module from Audi. Not the rSAP unit by the looks of it, but still better than the one in the car as it wouldn't read any of the SIM modules I had (read my Dad's ancient Virgin SIM, so was actually working). Anyway the kit I was supplied with had some cables attached and a 36-pin unit within the 54-pin connector for the module, the BT aerial and some MOST cables which it turns out I didn't need as I already had a kit in the car. Fitting was relatively simple once I'd found the correct wiring diagram (thanks to Figure11 for pointing me to erWin) as all the documentation I could find on the web was for the US OnStar to BT conversions which have different pinouts. Procedure: 1 - Unbolt the passenger seat. it doesn't need to be removed completely, just tilted back out the way (put the backrest forward and lift the seat base up to max for best clearance), you may need to wind the seat forward and back to access the bolts (T50). 2 - Remove the plastic trim along the kick plate next to the door. This just lifts up then pulls up and towards the back of the car. 3 - Unclip the seat power cable from the guide at the bottom of the seat. 4 - Pull the carpet forward from the air vent under the seat a bit, it's split at that point already, being careful not to strain the power feed for the chair which goes through a hole in the carpet about 6 inches in front of the split.Then lift the carpet from the door side. 5 - Unclip the seat power from the holder under the carpet and push the carpet back towards the central column (using the seat rails to hold it out the way). 6 - the Car Kit is in the box to the far left nearest the door hinges, pop it open and disconnect all the cables. 7 - Get the 36-pin connector for the BT kit, and the 42-pin connector for the old kit side by side and pop the followin pins from the old connector into the new positions on the old connector leaving the rest behind. OLD - NEW 33 - 14 - Diagnostics 42 - 11 - MIC + 41 - 12 - MIC - 15 - 10 - Terminal 31 (or Earth to the rest of us) 16 - 2 - Terminal 31 35 - 1 - Terminal 30 (or +12V for real people) Pin 3 on the new connector is a 'remote on' for the aerial amplifier which I don't think I have as there was no associated cable on the old kit as it had a built in unit. 8 - Connect it all back up: BT aerial, MOST loop, 54-pin 9 - Test! Sit back in shock that it actually worked 10 - Re-assemble. - Close the unit's box, refit the carpet while clipping the seat power cable back in, put the door trim on (be careful not to break the clips!) and re-bolt the seat down. 11 - Enjoy your new bluetooth car kit. It's a hoot with the SDS module, taking 5 minutes to dial a number Much quicker with the turney knob thingy or just use the phone to do it. Still to do: - Remove the old phone handset from the centre console. - Fit some USB sockets in there to charge my phones so I don't have the cable trailing around.
For reference this is exactly the same pinout diagrams for the rSAP compatible modules as well. After I trawled through and double checked
Just buy part number 8K0 051 592 for the 54 pin connector to make it a tidy job. |
Does anybody have the part numbers needed to swap over from the fixed handset to the bluetooth ?
I'm not bothered about the rsap functionality, I just want to be able to pair the phone with the car and use the MMI / Multi func steering wheel. ETKA isn't too clear and Audi are clueless, all I got from the parts chap was "that wouldn't be an Audi approved upgrade !"
2003 D3 A8 4.2 Atlas Grey - Factory: Adaptive lights with coming home function, 19" wheels, Solar Sunroof, Bose, Nav, TV, Paddle shift sports wheel, sports suspension, sports seats, rear seats with electric lumbar adjustment, heated seats and climate all round, ski hatch, int light pack, auto dip/fold mirrors, voice command, cordless phone, wooden gear knob, towbar, power boot lid After: LPG, AMI with HDD Pending: DVB-T Tuner & fixing niggles |
You can use quite a few modules in all honesty, Mine was a Q7 one. As long as it's for the early MMI high systems (Not A4) from an A6, A8 or Q7 you are generally fine.
Then rerun your 5570 updates through to ensure all is well. |
Looking round ETKA it looks like I need 4E1 862 335, does that part number look right ? If so what other bits would I need to install ? I'll give TPS a call to get a price - I'll sit down before dialling
You could also try craig @ tclsatnav.com for a fitted price.
Or kufatec.de Assuming it comes with the connector block, you need nothing apart from tools.
