Old 26th March 2022, 07:37 AM
They are usually a bit brown but nothing remarkable. I cut the Murple's filter open, which had 323000 miles on it was just a bit dark. No crud or blockages.
Some progress from last night - rear calipers painted to match the fronts
Printed alignment spacers to line the subframe up with the body. There's no load on these - they are simply there to hold everything in the right place while the bolts are done up.
Subframe complete and ready to go back on. I keep looking at this and wondering whether a Tesla motor would fit in it
Reassembly is the reversal of removal Position it in the right place on the pallet jack and lower the car on to it
Bolted back in
B-roll shot
A few bits to reconnect, but it should be back on its wheels today
ID:	28085   Click image for larger version
ID:	28086   Click image for larger version
ID:	28087   Click image for larger version
ID:	28088   Click image for larger version
ID:	28089   Click image for larger version
ID:	28090   Click image for larger version
ID:	28091   Click image for larger version
Old 26th March 2022, 09:20 AM
An S8 FE-E............ hmmmm call to action for someone I bet
Paul
Gosport UK
________________________
Audi S8 2002 FE Avus Silver / Extended Red Leather.
Daily Driver: BMW 3 series GT - Just more practical for my camping trips!
Old 29th March 2022, 07:31 AM
Changed at recommended intervals
I wonder what it looks like inside?
I cut mine open at 17yrs old and around 110k
http://forum.a8parts.co.uk/showthrea...ht=fuel+filter
Definitely discoloured .....
Old 29th March 2022, 07:47 PM
Are there alignment spacers used during first assembly? Just curious if the tolerance between the sleeve in the bush and the bolt is to allow for some 'lateral' adjustment to align the front and rear subframes or wheelbase lengths.
Paul
Gosport UK
Old 29th March 2022, 08:57 PM
That has a nice ring to it
Old 29th March 2022, 09:10 PM
I believe the factory will have used an assembly jig based on the holes in the body, similar to what I showed in Ricky's Van Attack thread. They may or may not have then moved the subframe around during the wheel alignment, however that is not an option to us now because wheel alignment companies don't go in to that much detail, and I can't afford my own machine!
As with the front subframe, I'll line the rear up exactly with the features on the body, and unless there is something spectacularly wrong with the alignment I will leave it alone
Old 2nd April 2022, 08:28 AM
A few updates from the last week as I'm finishing off, putting bits of trim back on etc.
I had the back bumper painted as it was a bit of a mess, and also replaced the lower section with a better one.
Its quite difficult to reassemble a freshly painted bumper without damaging it so I covered pretty much the whole thing in masking tape. I also replaced the worn out brightwork but forgot to get a photo
Rear tray repaired and refitted. This had been mangled by someone who couldn't get the screws out, but some heat allowed me to massage it back in to shape
Bumper on
Underneath completed
Unobtanium antenna grommet - the last one as far as I know
Another unicorn part - a boot panel with all four clips intact!
Most of the boot back together, although I do need to remember what I did with the spare wheel!
The engine bay is also complete
Agenda for the weekend is an eyeball alignment so it can go for a proper one next week, some interior parts back in, put the audio system back in, and swap the door mirrors as the motors aren't working (which I didn't spot while the door cards were off )
ID:	28103   Click image for larger version
ID:	28104   Click image for larger version
ID:	28105   Click image for larger version
ID:	28106   Click image for larger version
ID:	28107   Click image for larger version
ID:	28108   Click image for larger version
ID:	28109   Click image for larger version
ID:	28110   Click image for larger version
ID:	28111   Click image for larger version
Old 2nd April 2022, 08:38 AM
Ronin Ronin is offline
Talking
I think those boot dividers are still available for £120 a piece haha.
Excellent work!
Old 2nd April 2022, 09:04 AM
With the aluminium bar bracing the chassis do you need a brace on the subframe? I have both on mine and wondering why.
Paul
Gosport UK
Old 2nd April 2022, 09:13 AM
You must mean this one?
The spare wheel has not fared too well
That will buff out????
Paul
Gosport UK
