Go Back   A8 Parts Forum > A8 D4 > D4 - Sat Nav, ICE, Audio & TV
D4 - Sat Nav, ICE, Audio & TV All in car entertainment discussions including MMI 3G Plus
Old 24th December 2019, 04:21 PM
H-M3 H-M3 is offline
Ray you don’t need no maps! With you being on the road 24/7 I am sure you know the roads back of your hand.
Audi A2 1.4 petrol 2002
NO VCDS rely on Neeldub
Old 24th December 2019, 05:48 PM
Adrian, how easy is it to do the map update? I drove past yours on Sunday evening on my home from Germany.
It's not difficult to do, but the maps need activating with a small file on an SD card after map installation, then there's a software version management error to remove with VCDS. Takes 2-3 hours in total, depending on the speed of the SD card.
Ideally wants a battery charger rigged up throughout so the battery doesn't get a hammering.
Old 24th December 2019, 08:05 PM
Even I don't know everything.
OK I like to brag and make out I've been everywhere, but truth be told, everyday is a schoolday.
Old 24th December 2019, 08:09 PM
For my 80 year old brain that is starting to sound a bit complicated.
Connecting a charger is no problem, that was my line of work when I first started to earn a proper crust.
Think the best way for me is to forget it, unless you put the kettle on and I drive down your way.
Old 24th December 2019, 09:07 PM
Always an option if you're in this neck of the woods
Old 24th December 2019, 09:15 PM
Might be well worth the drive down to actually meet up with you.
But then again I have been promising that for a few years. Lot easier now that I have dropped all the chauffering work.
PM me when you have a spare couple of hours and I'll remortgage the house to buy some fuel.
