Old 10th December 2015, 12:27 PM
Default Reversing Light Bulb
Does anyone know the fitting size for this?
I know that it is 12v 16W bayonet.
But iirc the bayonet size is smaller and I do not want to open the cluster just to check the physical size before I visit Halfrauds or a stealership to buy a bulb.
Old 10th December 2015, 12:51 PM
http://www.ebay.it/itm/121327400104
I think it comes with a plastic base and in a metal bulb holder - BUT
I *think* it is a T15 bulb stuck in a bulb holder and you get the bulb holder with it, but not sure.
The Audi P/Ns are:
pre-facelift 4E0945981 bulb with black socket
facelift 4E0945981A bulb with grey socket for back-up light 12V16W
Probably the same part anyway?
Old 10th December 2015, 01:01 PM
Ray, I've deleted my previous comment as now I think the only replacement is to buy part 4E0945981, that Snap posted, from the Sealership.
Matt
Old 10th December 2015, 03:04 PM
Matt, Thanks for the reply that I did not manage to see, deleted before I returned home, now I'll be losing sleep wondering about what piece of smart wit I missed
Snap, Thanks for the informative reply, ebay page from Italy, advertiser in Herefordshire and he appears to be working for Deutscheparts.
End result is that it could be a T15 holder.
The reason for this is that I want to replace my "going backwards" lights with LEDs, but I believe that they are canbus monitored (unless someone knows better) and I will have to run incandescent bulbs in parallel like as wot I aff dunn with my sidelights. I'm looking at CRE LEDs for their light output. My current Audi issued lamps are a bit dull.
Old 10th December 2015, 03:14 PM
I don't want you loosing sleep Ray.... My original comment
As with Snap, my thought it was a T15 / W16W.
But looking at photos the fitting does not look it takes the T15 capsule.
It may take a PU20d-1 / HPC16W
Sorry Ray I can't be 100% sure.
Deleted because PU20d-1 / HPC16W can't be separated from their base, so it was wrong info even though they look the correct shape and are 12v16w
Matt
Old 10th December 2015, 06:41 PM
Thanks for that Matt.
Having been out on a couple of jobs since has given me time to collect my memory. I think that T15 is the capless type of bulb like the sidelight. I am sure the reverse and brake lamps are bayonet.
I'll try and find time tomorrow to look at the assortment that Halfrauds carry and see if they have something similar.
